Swapping in a 3.5L
Old Feb 20, 2006 | 08:53 AM
chris'smax's Avatar
Swapping in a 3.5L
Just incase some of you guys don't visit the FI forum, i spun a rod bearing in my motor last week while dynoing and now have to replace the motor. Today I am starting a 3.5L swap while keeping the supercharger. Figure i would post this in here to give some of you 5th gen guys some heads up incase you need to replace your 3.0 so you can do the 3.5 swap. Hopefully it will be done by the end of the week.
The setup will be as follows:
3.5L w/ SC (2.87 pulley, cai, 3"charge pipe)
ARP rod bolts
JWT 3.0L cams(if my buddy comes through )
Hothsot headers
Greddy Emanage w/ injector & timming harness
3" exhaust cuttout
J&S (next couple of weeks)
Cooling mist water/ alcohol injection
Old Feb 20, 2006 | 09:08 AM
97neptune's Avatar
SWEEEEETT!!! s/c 5.5! good luck with it. hope everything goes smooth
Old Feb 20, 2006 | 09:56 AM
igzy's Avatar
I Know Kwaliti
Can't wait to read more about it Considering the mods in your sig, I take it you have an automagic... Is it a beefed up 2K tranny? Asking so just to keep in mind I ever decide to go the same route...
Old Feb 20, 2006 | 10:37 AM
Yayomax's Avatar
still brewin'
are you doing any type of write-up, I'm really considering this also
Old Feb 20, 2006 | 10:58 AM
indecentmax's Avatar
would be awsome to see if the S/C works with the 3.5. Good Luck
Old Feb 20, 2006 | 11:05 AM
Nismo3112's Avatar
Custom User Title
It will bolt right on since he is using the 3.0 timing covers.
Old Feb 20, 2006 | 11:35 AM
i have yet to see anyone S/C a 3.5L. If its as simple as using 3.0 timing covers why dont more S/C their 5.5 gens
Old Feb 20, 2006 | 12:49 PM
vsamoylov
its not considered a 3.5
Old Feb 20, 2006 | 01:31 PM
Nismo3112's Avatar
Custom User Title
It wont work with 5.5 gens.
Old Feb 20, 2006 | 01:33 PM
vsamoylov
5.5 gens maximas are e-gas. 2k-2k1 are easier.
Old Feb 20, 2006 | 01:56 PM
LA02MAX's Avatar
holy crap, that sucks about your old engine, but it's a good thing that you'll be getting the 3.5...you'll love it
I think next you should do a tranny swap though
just wondering, but did you get any runs in before it happened? and if so, how were they?
EDIT: pwned by searching....nice numbers, though...
Old Feb 20, 2006 | 03:20 PM
chris'smax's Avatar
I am not going to do a write up since there is already a faq about the swap, but i will include some pics and tips about the swap.
The reason you don't see any 5.5 gen w/ the SC is because you have to use 3.0 timming chain cover(inner and outer) and the timming gears, which means there cam and crank position sensor wouldn't work(i don't think)
Old Feb 20, 2006 | 03:29 PM
Gjohnson's Avatar
Hmmmm.... I can't wait to see this. And I thought your car was bad before.
Old Feb 20, 2006 | 03:52 PM
djbonsu's Avatar
this is definitely something i NEED to see end results!!! ....are you gonna do a tranny swap as well???....(i.e. 6spd/HLSD??)....
Old Feb 20, 2006 | 05:16 PM
03maxima1's Avatar
Is doing a dyno that dangerous in terms of things going wrong? How did that happen?
Old Feb 20, 2006 | 07:36 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
His engine went from a improper engine tune... there are really no dangers with dynoing the motor. DynoJet puts LESS stress on the engine than you would while racing, or even runing it on the street. Its not a LOAD type of a dyno like a DynaPack.
Reason 3.0L timing chain cover and no VTC sprocket won't work on a 3.5L 5.5Gen is not the "E-gas". That has NOTHING to do with it. You have to remove your VTC sprockets and this will set the check engine light for VTCs not working properly. It will most likely put your ECU into a LIMP home mode and it will not work. Someone who knows how to program ECUs could POSSIBLY remove the VTCs from the ECU program (kinda like JWT can eliminate EGR function or EVAP functions from the ECU programs) and make it run similar to a 3.0L ECU. But I doubt TechnoSquare is able to do anything like that.
Old Feb 20, 2006 | 08:21 PM
Mass_Media's Avatar
Mass_Media™
So by that logic then couldn't we get a 3.0 ecu and have JWT do there work then run a supercharger?
Old Feb 20, 2006 | 08:34 PM
chris'smax's Avatar
no because you are still using the 3.5 sensors and wirring harness
Old Feb 20, 2006 | 08:49 PM
3.0L ECU will not work with a 5.5 gen. 5.5 runs CAN BUS data networking, where older cars like the 4th and 5th gen do not use CAN to interface amongst other systems in the car. You can't mix diff systems, like CAN to non CAN, and non CAN to CAN.
JWT can't make a ECU to save their life for a Maxima, do you think we could trust them to make a ECU that would do ALL that for us ? They can't make ECUs for anything past 96 anyways.
I would keep everything intact- CVTC, and all the 5.5 gen stuff and make a roots type blower with a extenssion shaft infront of the valve cover- aka COMPTECH setup for the TLs. That setup will gain you some significant power, and if thats not enough to justiffy your HP cravings- you can always turbocharge and use piggy pack engine managements to controll your A/F, timing etc.
In reality, Stillen SC is not all that great. And in order to make it work on a 3.5L it would require lots of re-engineering of the car, just so you could gain a few ponies. After spending all that $$$ on my car, wouldn't you think I would have a SC on my car by now if it was really THAT great ?
I know of a company who can make a SC for our Maximas, it will be similar to that of the 3.8L SC GM motor used in the Pontiacs and Buicks. They make one for my Q45 for bout 3500 bux and it makes ALOT of power. There would need to be enough interest in the roots blower for them to make it, and a guinea pig would be required.
Old Feb 20, 2006 | 08:52 PM
getbigtony's Avatar
rebuild the motor! use some forged parts and ur set. then crank up the boost!
Old Feb 20, 2006 | 09:09 PM
chris'smax's Avatar
Why would i forge the internals when they are already more than strong enough? I spun the rod bearing due to detonation which was caused by my timming being to advanced
Old Feb 20, 2006 | 09:29 PM
You will not find the limits of a STOCK VQ motor using a Stillen SC when properly tunned like Chris is using. There are NO benefits from using forged internals when using just a SC. Forged internals "sound" nice when you put them in your sig lines and make all the lil ricers look at you like your some kinda god. But in reality your engine will "sound" like a coffee can full of marbles on cold winter morning start ups from em forged slugs There is more to an engine than just a buncha un-needed parts, its all bout the tuning. I can blow your built motor with a crappy tune just as eassy as I can blow a stock motor.
Years ago Hondas where strugglin to make 300HP on stock bottom ends with turbos, now that we have some REALLY good engine controll options like affordable standalone ECUs, good piggy backs and most of all AFFORDABLE Wideband 02 sensors, people have taken the engine power output to a whole new level. Back in the mid 90s, 300HP Honda or Nissan was da BOMB, now 300HP can be attained with a simple tune and small snail feeding your engine with almost perfect powerband to the boot.
Old Feb 21, 2006 | 06:53 AM
vsamoylov
i never said it was because of e-gas. i said that is oen of the differences between a 5th gen and 5.5 gen
Old Feb 22, 2006 | 06:13 PM
zheka's Avatar
what was the miles on your max when you spun ur rod? how often did you replace the oil? did you beat on it?
Old Feb 23, 2006 | 02:38 PM
scmaxima2k's Avatar
Good luck with the swap, I look forward to hearing how it goes.
Old Apr 18, 2006 | 08:57 AM
MaxBoost925's Avatar
Drug Money
How's the progress on this project so far? I'm going to be doing the same.
Old Apr 18, 2006 | 09:14 AM
sciff5's Avatar
As cool as any blower would be for our car. Based on how torquey our motors are already and our lack of traction. I would much prefer a centrifugal type supercharger system. We really need more power on the top end like a turbo would provide (and centrifugal to a point). Roots blowers are also much more prone to heatsoak.
Old May 24, 2006 | 11:32 PM
Drug Money
DUDE. how is the progress?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
