wtf....
Old May 24, 2006 | 04:10 PM
zax 20th ae's Avatar
wtf....
my ses light is on had ecu scanned p-0430 code popped up what the hell is this.
Old May 24, 2006 | 04:47 PM
alpinestars™'s Avatar
THIS IS...
Google always helps. The code you mentioned is: Catalyst System Efficiency Below Threshold (Bank 2). If you are under 80K get your cat replaced at a dealer...
Old May 24, 2006 | 04:51 PM
irish44j's Avatar
retired moderator
look in the stickies above and your question shall be answered
Old May 24, 2006 | 04:57 PM
merovi's Avatar
could also be a precat. but I will tell you that if you plan on buying a y-pipe, get it before you replace anything that will cost you money. I had the same code, installed my y-pipe, and now the code has dissapeared.
Old May 24, 2006 | 04:59 PM
THIS IS...
I forgot about the precats. Could be one of those b!tches too...
Old May 24, 2006 | 05:06 PM
ive had a y pipe before the problem came up though,
is an install on one of these precats easy or does major **** gotta be removed in order to get to them????
Puppetmaster's Avatar
P0430 IS for the front pre-cat, someone already posted that it was Bank 2, which is the front bank. It has nothing to do with the main cat. Plus he has an 01, so there are no O2s behind the main cat that could tell if wasn't working right.
Old May 24, 2006 | 05:09 PM
Mass_Media's Avatar
Mass_Media™
So you have a After market y-pipe? If so then its your main cat. Like said before if you have under 80k miles then go to a nissan dealer and get you cat replaced
Old May 24, 2006 | 05:11 PM
It doesn't matter if you have a y-pipe or not. Your car is CALI spec and there is a front pre-cat that is not replaced by the y-pipe.
You can either replace the pre-cat which will be a pain, get headers, or you can get an O2 sim to simulate a working front pre-cat.
If you want local help, let me know.
Old May 24, 2006 | 05:32 PM
fyi, i have 104,000 miles on my car.
and replaced the oem cat with a high flow cat a while ago.
so its not that.
Old May 24, 2006 | 06:23 PM
merovi's Avatar
so its not that.
your high flow cat might be garbage...so that could be your problem. I've not heard many good things about high flow cats or our cars.
Old May 24, 2006 | 06:32 PM
Please explain to me how a faulty main cat or high flow cat will throw the code for a Bank 2 pre-cat, P0430, on a CALI spec car.
Old May 24, 2006 | 06:51 PM
id like to hear this too..
Old May 24, 2006 | 07:46 PM
merovi's Avatar
i dont know the explaination or even where to start, i've just read alot about people replacing their cat and having it make a difference. Like they replaced the sensor first, and the code would come back, then they replace their cat and the code would go away and stay away. Just what i've read from other threads.
Old May 24, 2006 | 09:33 PM
FriscoMaxima's Avatar
does driving with P0430 damage the engine in any way?
Old May 24, 2006 | 09:36 PM
MaxBoost925's Avatar
Drug Money
i've been doing it for 3,000 miles, don't hurt a thing.
Old May 24, 2006 | 09:52 PM
damn, i still suspect that those codes (P0420 and P0430) are caused by Cold Air Intakes. and i really do not want any reatarded SES lights on my dash...
Old May 25, 2006 | 05:54 AM
merovi's Avatar
nope, i have never had an intake
iceturbo
Apr 17, 2014 08:07 PM
getflushed
Nov 11, 2011 03:08 PM
Pfc Woody
Jul 19, 2011 08:01 PM
AGRECORDS
Oct 21, 2005 04:40 AM
