6spd swap
Old Feb 21, 2006 | 09:06 PM
  #41
Hoooper
so i need a different trans mount, not engine mount? i dont need new axles do i?
Old Feb 21, 2006 | 09:12 PM
  #42
99 SE-L
Yes, you need a Transmission mount and MT Axles.
Old Feb 21, 2006 | 09:30 PM
  #43
Hoooper
i sent you a pm, plz check
Old Feb 21, 2006 | 09:41 PM
  #44
99 SE-L
Hey the site is;
WWW.CAR-PART.COM
Old Feb 21, 2006 | 09:48 PM
  #45
Hoooper
thx
10char
Old Feb 21, 2006 | 10:05 PM
  #46
NmexMAX's Avatar
dot dot dot ...
www.car-parts.com > www.car-part.com
Old Feb 21, 2006 | 10:18 PM
  #47
BlackBIRDVQ's Avatar
drag racing is for wussies
Originally Posted by vsamoylov
Please get the facts straight. half og the stuff that you listed is wrong and I personally talked about the mount.
3) not true. the engine mount stays in place. Nothing o nthe engine side has to be touched. The tranny mount is different but that is a simple task which i have talked about alot of times.
4)not true either. linkages fit without any problems.
5)that can be solved with the bracket that holds the abs. just get one from a 6 spd car and it bolts into the same place.
Most of the stuff that people posted in this thread is wrong and useless information. I am not saying all of it but most of it.
3- sorry that I said engine mount but to me they are all engine mounts regardless if it holds the tranny or the engine. It needs to be welded up as the tranny one is diff between auto and 6spd AND 5spd trannies.
4- I've done it and the shifter linkage will NOT fit in the small hole that is in the firewall. Cable shroud ends are very large and will not fit in the small hole, if it did I wouldn't have to sit there for 2 hours enlarging the hole.
5- ABS has to be moved and lines have to be bent a lil bit- just stating the facts here.
Its not like I just got a licence 2 days ago, and just started posting here bout working on a Maxima. I uphold my comments valid. Show me a 5th gen body trying to fit the shifter linkage though the small AT linkage hole without enlarging and I will be VERY impressed.
Old Feb 22, 2006 | 06:41 AM
  #48
maxS
MAN THIS IS becoming UNBELIVABLY outrageous.... my understanding is that some ppl need help with a swap in first place. That's how the thread started. Why not really help them/him then???? Why instead give out this pile of BS???? Have you personnaly done this kind of work? What's your deal with "very large ends" and "small hole"??? Is it something personal you refer to? Is it?
Old Feb 22, 2006 | 10:00 AM
  #49
upstatemax's Avatar
I would take BlackbirdVQ's opinion very seriously. He knows what he is talking about and can and I would bet has done everything you can think with a car several times over.
Mike is giving him the facts of life with this swap and IS helping him, if he blows off Mikes opinion and trys anyway... Good for him, but he will regret it.
Mike has helped a ton of people (including myself) on this board on everything from headers to headlights.
Old Feb 22, 2006 | 12:17 PM
  #50
boondoxmax's Avatar
I agree. All the money and aggrevation involved won't be worth it. Just trade the autotragic in and buy a 6speed. BLACKBIRDVQ knows what he's talking about
Old Feb 22, 2006 | 02:51 PM
  #51
maxS
wrong info IS NOT helpfull
Old Feb 22, 2006 | 05:15 PM
  #52
vsamoylov
How can you say that they are all the same to you. And the 6 spd tranny mount doesnt have to be welded anywhere. it is bolted to the frame. the 5 spd mount and auto mounts are welded to the frame. not the 6 speed mount.
again on the linkages. they fit through the holes. on my car no holes where enlarged and when maxs did a swap on his 5th gen, he didnt enlarge any holes either.
the abs bracket is didferent on auto and 6 speed but it bolts to the same location.
Old Feb 22, 2006 | 05:59 PM
  #53
sure its bolted to the frame on a 6spd car- but automatics would eighter have to have the mount bolted to the frame with nuts welded on from the inside of the frame rail (how do you do that ?) or weld the bracket directly to the chassis like I've done.
Regardless.... dream on bout the conversion.
Old Feb 22, 2006 | 06:01 PM
  #54
vsamoylov
didnt you miss the part where i said the auto mount is welded to the frame?
Old Feb 22, 2006 | 06:16 PM
  #55
SuperStasiu's Avatar
Last time we did a swap on a 5spd the tranny mount waas bolted on,
so what you guys are saying is that this 6spd swap is like a 5spd, just a drop in???
LOL ahahaha
Old Feb 22, 2006 | 06:30 PM
  #56
vsamoylov
LOL ahahaha
well yeah the moount itself but the bracket is welded to the frame. on the 6spd its completly different.
Old Feb 22, 2006 | 09:31 PM
  #57
Hoooper
are you sure about that? mine sure looks like its just bolted on. if it is, do i need a new BRACKET or just mount?
Old Feb 23, 2006 | 12:10 AM
  #58
A33 VQ30DEK's Avatar
just a new tranny mount
Old Feb 23, 2006 | 07:40 AM
  #59
Hoooper
shweet
10char
Old Feb 23, 2006 | 08:42 AM
  #60
vsamoylov
yeah the bracket on auto and the 5spd is welded to the frame and the mount is on the tranny. you stick a bolt through the mount and the bracket. on the 6sp the mount is bolted to the tranny and the frame so the bracket is gone. and can anybody tell me why people are giving opinions that have never done this swap and dont know what they are talking about?
Old May 23, 2006 | 10:54 PM
  #61
nismology's Avatar
So all you have to do is tap the holes into the frame?
Old May 24, 2006 | 04:16 PM
  #62
namahs's Avatar
hey,
does anyone know how to bleed the clutch on a 2002 maxima?
Old May 24, 2006 | 04:19 PM
  #63
Y2k2maxse's Avatar
if i were you..i would sell it and buy a 6speed...much more reliable...as they cover their work for only 12,000 miles. also may be harder to sell if they know the tranny is swapped.
Old May 24, 2006 | 04:48 PM
  #64
Mass_Media's Avatar
Mass_Media™
Originally Posted by namahs
hey,
Donate and search or google it.
Old May 24, 2006 | 08:25 PM
  #65
eyecon7's Avatar
hey just wondering well this swap be eZ''rrr if i got a parted out vq engine with manual transmission or do i have to worry about other things
Old May 24, 2006 | 09:53 PM
  #66
nismology's Avatar
Good lord.....i bump up this old thread to get an answer to a relevant question then these posts......
Old May 25, 2006 | 12:43 PM
  #67
vsamoylov
drill new holes in the frame and bolt the tranny mount on. to get the old one off, get rid of the spot welds.
now since there isnt any threads in the frame, you will have to use your head and think of something creative.
Old May 25, 2006 | 06:59 PM
  #68
maxS
Originally Posted by shift_2kmaxima
u'll be the first one to do it on a 5.5 gen..
i dont think it has been done b4 on a 5.5 gen..
good luck bro, i'll try to look for some parts, if i find them i'll post them on here.
peace
it has
Old May 27, 2006 | 09:46 AM
  #69
rteenie22's Avatar
wow I kno how it feels to be 17 and have an auto tranny crap out on you. thank God mine was in my truck and not my max. the whole time it was down for repairs i was saying to myself if it was a manual i wouldnt be having these problems. but dad paid for it and im good. hey if they let you do 6spd swap go for it. i would get a fsm and study the diagrams for differences between auto and manuals though
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
