ECU reflash for MAF
Old Feb 22, 2006 | 01:19 PM
KyMan's Avatar
ECU reflash for MAF
I have a 2k1 auto. I'm at 74k miles and it is seeming more sluggish than it should be and I'm considering getting a new MAF. Just the other day I got a P0420 which is covered under a TSB and calls for an ECU reflash and possibly CAT converter.
Most people say when getting a new MAF that you should get the ECU reflashed by the dealer and I'm wondering if I get the ECU reflash done for my SES code and then get a new MAF a few weeks later will I need another ECU reflash? Or does the ECU reflash/update only need to be done once. TIA.
Old Feb 22, 2006 | 03:09 PM
Larrio's Avatar
The Definitive AE Master
you'll be fine with the new MAF. You can try resetting the ECU by disconnecting the negative cable to the battery overnight if you really want
Old Feb 22, 2006 | 03:12 PM
lex3015's Avatar
it doesnt even have to be overnight. most people just unhook it for a few hours and its good to go.
Old Feb 22, 2006 | 03:55 PM
MY2000MAX's Avatar
I'd like to know too. Is the update something that has to be done once does it have to be done only after the new MAF is in?
Old Feb 22, 2006 | 06:14 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
nissan has an update done through the consult 2 that they recommend in the tsb and even on the boxes of the updated mafs. myself and many others have the updated w/o the updated flash and have had no issues. it would be interesting to see the a/f difference between the two if any though. the new maf simply has the actual wire built up further in the housing to help keep the wire from being hit or grime building onto it.
Old Feb 22, 2006 | 07:51 PM
GimmeTorq's Avatar
A reflash overwrites the software that runs in your car's computer (ECU). This is sometimes needed when the manufacturer has upgraded the software to fix bugs or make it compatible with upgraded parts. This software is in persistent memory (it is stored in a programable read-only memory, that it is not lost even if battery power is removed), so you only need to reflash the ECU with the latest available software. But it is possible that the dealer may refuse to reflash unless they also install the MAF at the same time, if the only reason for reflashing is due to an upgraded MAF. Anyways, you won't have to come back for another reflash after installing the MAF, if you have already done so...
Old Feb 23, 2006 | 07:09 AM
KyMan's Avatar
Sweet thanks for the help guys. I just wasn't sure if they only reflashed part of the ECU (the part containing my P0420 code), but I guess they do it all.
I guess it might be time for them to advance my timing to 17^ while I'm in there and hooked up to the machine.
TallTom
57
Oct 14, 2025 05:16 PM
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
ballerchris510
Sep 10, 2015 09:35 PM
