Sunroof not opening (2002)
Old Feb 24, 2006 | 09:05 AM
maxspeedse02's Avatar
Thinks he is fast
Ok guys I have a 2002 max and for some reason my sunroof will not open. On the 5.5 gens the switches are a little different than the 5th gens, and the one that is malfunctioning is the one the slides back (closest to the driver). I can open it using the vent button on the right however that opens 2-3 inches everytime you press it so it is a P.I.T.A. also not what that button was designed to do. I'm hoping it's just the switch and not a motor but I would like to see if anyone else has had this problem. I'm not sure if there are different motors that operate each switch ( I guess it is possible) but I can open it with the vent switch like I said further up so it is getting power. Any help would be appreciated
Old Feb 24, 2006 | 09:17 AM
Puppetmaster's Avatar
Did you disconnect the battery recently?
Old Feb 24, 2006 | 09:26 AM
crispykid717's Avatar
Bigger than Jesus
Check your owners manual. The fix is in there.
Old Feb 24, 2006 | 09:33 AM
Thinks he is fast
I did disconnect the battery installing an amp. I'll check the owners manual thanks.
Old Feb 24, 2006 | 09:37 AM
That's it then.... the reset procedure is on page 2-29 or something. All you do is hold the tilt close button down for a bit.
Old Feb 24, 2006 | 11:48 AM
Starchild2K2SE's Avatar
This happened to me before and I was like,WTF? But it started working again on it's own in about a month.....this problem is very weird....
Old Feb 24, 2006 | 12:06 PM
wanaMax's Avatar
I have a similar problem with my 2000. The tilt works but the slide goes like an inch then I have to push the button again. It takes pushing the button like 7 times before the sunroof is open. I is a POS. I tried resetting mine but it did not work. I also tried a new switch, but still no dice. so i uess I will have to live with it for a while before I figure out what to do.
Old Feb 24, 2006 | 01:03 PM
Lethal's Avatar
If you want to perform the sunroof reset here it is:
• If the sunroof is open, press the tilting switch repeatedly toward tilt "Down" to fully close the sunroof.
• After the sunroof has closed all the way, keep pressing the tilting switch towards tilt "Down" for more then three seconds.
Thats exactly as it reads from a sunroof TSB. See if that fixes your problem.
Old Feb 24, 2006 | 01:08 PM
spdfreak's Avatar
I don't have a sunroof, but I think i've heard of this problem before, and the fix should be in the book.
Old Feb 24, 2006 | 05:59 PM
Bezzle01's Avatar
I thought my car was freakin out when it started doin that lol. I did basically the same thing to fix it by accident.
Old Feb 24, 2006 | 06:59 PM
Thinks he is fast
Yep works fine now. I feel like such a n00b but that sure isn't the first thing you would think to do when your sunroof doesn't open.
Old Feb 24, 2006 | 07:32 PM
BLK2BLU's Avatar
Even worse when it wont close
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
bigdogsteve
Jan 31, 2018 04:18 PM
jonreidhead
Jan 6, 2016 09:38 AM
09maxshawn11
Sep 30, 2015 10:28 AM
