Front Sway Bar
Front Sway Bar
I feel ashamed to ask this but I think my front sway bar or some other linkage may be loose...I have clunking going on on some bumps and not on others, it is very inconsistant yet happens very often. I would like to check for looseness and replace the FSB bushings.
I can not easily see what looks like a sway bar when i look under the from the front lip. Can anyone guide me, give me a link or post/ email me a pic of one.
Sorry to be two years old.
The swaybar doesn't hang under the body of the car, only the ends and links are visible, I believe. If you jack up the car you should be able to track it starting at one of your wheels. If you have a sound like you wheel is falling off it may be your FSB end links. I had this problem.
I would say it is the end links. Most folks who have had the symptoms you describe, myself included, have had to have them replaced... and at least two of us have had to have them cut off with a torch.
What was the damage? Is it possible to fix yourself or would I be better off just having it done.
thanks for your help
FSB, End LINKS, NOISE.
I had both endlinks replaced and noise is still there, check this thread, you might be experiencing the same issues......
http://forums.maxima.org/showthread.php?t=295640
Originally Posted by miksen
Yes, someone else mentioned to me that may be the problem.
http://digitalpolo.com/2002MaximaSE/.../FrontSwayBar/
It should have some pictures that may be of use to you.
Thanks Puppet
Originally Posted by Puppetmaster
Here's Polo's write up on the sway bar bushings replacement:
Originally Posted by boondoxmax
End links. PITA common problem with the max
The dealer just said they were broken. Rust had to do with it. My warranty covered it ($200) but I paid for an extra hour of labor due to rust.
Originally Posted by 97neptune
if its the transverse links youre talkin about, id go right back and get reimbursed for that hour that you paid for. Nissan will pay for that extra hour if your dealrship calls it in. this was a safety recall, customer pays nothing!
What recall?
http://www.nissanusa.com/form/0,,act...-51054,00.html
It doesn't include 2000s.
lowpost99
Oct 26, 2025 06:53 PM
adamgalazka
Feb 5, 2023 08:24 AM
