help...rubber to metal squeek when wheel turned left
Feb 28, 2006 | 08:19 AM
car was lowered on h techs about 2 weeks ago and im not sure if the noise is related since it just strated. sounds like rubber rubbing against metal when the wheel is turned all the way left. i dont see any contact between any parts, could it be a parck & pinion issue or anything else? thanx
Feb 28, 2006 | 02:45 PM
Sounds like the steering stop, cap, things.
I noticed that I had the noise, looked under the car, and saw where the contact (and noise was occurring). It wasn't until I read these threads that I realized there's supposed to be a plastic cap there to prevent the noise:
http://forums.maxima.org/showthread.php?t=436637
http://forums.maxima.org/showthread.php?t=436334
Feb 28, 2006 | 03:04 PM
agreed with above. I had a similar noise and it went away when I removed the steering stops.
Its just a bolt threaded into the lower part of your knuckle that comes into contact with a portion of your control arm at full lock
Feb 28, 2006 | 03:22 PM
unfortunately not, there is at least an inch of space even when wheel is turned all the way.
Feb 28, 2006 | 03:26 PM
So the circled bolt in this pic doesn't contact the circled area at all?
http://www.arches.uga.edu/~arslaan/bumpstop.jpg
Feb 28, 2006 | 04:00 PM
Quote: So the circled bolt in this pic doesn't contact the circled area at all?
nope, wish that would be the answer
