Y-Pipe emissions
Old Feb 28, 2006 | 11:19 PM
PerfectVQ I30's Avatar
Y-Pipe emissions
ok, so i understand that the y-pipe will take out the precats, will this past emissions at inspection? I live in houston so they plug a obd connector and take ecu readings for pass fail. No tail pipe probe. I wanna get a cattman y-pipe with straight through b pipe, will this be loud? im gonna run stock muffler.
Old Feb 28, 2006 | 11:25 PM
alpinestars™'s Avatar
THIS IS...
I believe if you dont have a CEL you will be fine.
Old Mar 1, 2006 | 01:34 AM
so as long as i have no cel the readings from sensors mean nothing... theyre not looking for a certain reading? Anyone in TX know anything, i just wanna make sure before i buy
Old Mar 1, 2006 | 05:52 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if your 2000 is a fed spec then both precats will be removed but if it is cali spec then only one precat will go.
Old Mar 1, 2006 | 05:55 AM
Puppetmaster's Avatar
Try asking in the regional forum too:
http://forums.maxima.org/forumdisplay.php?f=16
Old Mar 1, 2006 | 08:11 AM
frankd121's Avatar
pre-cats are there for cold start emissions; once the main cat reaches operating temperature, the main cat primarily takes care of emissions.
Old Mar 1, 2006 | 08:25 AM
Max_Vader_2K's Avatar
2000 FED SPEC with a Y-pipe and no fails yet 5 years strong
Old Mar 1, 2006 | 11:10 AM
my car is cali spec, i was just curious what they look for when they plug u in directly to the OBD.
Old Mar 1, 2006 | 01:24 PM
SoonerFan's Avatar
Cletus
if your car has warmed up you will pass
Old Mar 1, 2006 | 01:51 PM
sloppymax's Avatar
the obd2 port will tell them if there are any codes you are throwing either that are either engine or transmission related.
Old Mar 1, 2006 | 01:55 PM
SoonerFan's Avatar
Cletus
you wont get a code from the y-pipe
Old Mar 1, 2006 | 02:03 PM
tdogg169's Avatar
I got a code with my y-pipe. P4030 (i think). I have a 2k2 fed spec. In Houston, they do check for codes. Most place dont do visual inspections. As long as you dont have a code, you will pass. I had to get 02 sims. Works great.
Old Mar 1, 2006 | 02:07 PM
SoonerFan's Avatar
Cletus
all 2k2 (and 2k3) are cali-spec
Old Mar 1, 2006 | 09:29 PM
You have a 2002 CALI spec because all of em are CALI spec. Your P0430 code is for the front pre-cat and that failure was not because of your y-pipe because the y-pipe does not replace either of the pre-cats.
Old Mar 2, 2006 | 07:40 AM
Le1717y's Avatar
subscribing..
Old Mar 2, 2006 | 09:18 AM
VQ30GTR's Avatar
Not 100% sure about that. I went to emissions with my Warpspeed on, and no SES. Did not pass because the "catalyst" was not ready. I hit the clear DTC, just as a precaution the night before. They asked if I had any work done or Battery disconnected. They said drive it around a while for a week and come back. I did, same thing, did not pass, but the computer does a Catalys check every 400 miles or so. This did not pass, and got a SES light.
PO140 code I believe? So I put my stock pipe back on (with cat) and tried again. Did not pass.
Got a SES a few days later. looked at the 02 sensors, with some troubleshooting help from Blackbird, found the O2 sensor was bad. Replaced, kept stock y-pipe, passed.
Now last week I put on the warpspeed back on, have gone more than the 400 miles, but no SES as of yet, and no pending DTC's.
The catalyst is still reading "incomplete" as of right now. This would fail the emmissions test, right from the beginning.
If you are warmed up and they do the exhaust pipe test you would most likely pass. As far as the OBD, with the catalyst not ready, or incomplete, you will not even get to test, as they will fail you.
I will let you know in the next few days if the test passes, or stays incomplete. I am assuming that since it has been about 600 miles, and nearly 2 weeks, it will stay incomplete. Possibly an O2 sim would fix, but am selling tha car later this year, and will go back to stock. Did not want to monkey around with that.
Old Mar 2, 2006 | 09:56 AM
sloppymax's Avatar
the reason it failed is because you clearned the codes the night before. the ecu will go through a cycling phase for the next xxx miles and certain number of start ups. after that amount of mileage and no cel then you should be ready to test.
Old Mar 2, 2006 | 09:59 AM
Stardust's Avatar
F---ing Kangaroos
Thats backwards, fed spec has one and cali spec has two.
Old Mar 3, 2006 | 09:40 AM
VQ30GTR's Avatar
Yes, I know but when the car cycled through it's test, it failed again. This was 2 weeks after the initial run. I then put on stock Y-Pipe, it failed on the next ECU cycle as well.
This is how I found the bad 02 sensor. Now back to good O2 sensor, and Warpspeed - Y, It has not yest completed the Catalyst, and that is after 700 miles so far. It only took about 300 or so the last time. My point was if the ECM test is still incomplete you will not pass. So far with a working O2 sensor, y-pipe and 700 miles, it is still incomplete. Same start ups, same routine every day, should have given a SES by now. (No SES, and test incomplete).
Old Mar 6, 2006 | 12:28 AM
Where can i get an o2 sim, and how much. Will this complete cataylist?
Old Mar 6, 2006 | 07:19 AM
www.o2sim.com
Old Mar 7, 2006 | 12:02 PM
00Max00's Avatar
I'm in the similar situation. Have replaced MAF 1 1/2 weeks ago. Car has been driven 400+ miles, no SES, catalyst still not ready. Don't know how long it take to get the catalyst ready.
Old Mar 7, 2006 | 01:03 PM
stepneybluebell's Avatar
I have one and i was OK
Quickywd01
Sep 21, 2016 09:36 PM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
