Sunroof question
Old Mar 6, 2006 | 11:06 AM
bpe383's Avatar
Sunroof question
Just got a 02 maxima. Had a great deal of wind noise coming from the sunroof area. Took the air deflector off, as I don't care for them. It helped a great deal.
Washed the area around where it was, and noticed the sunroof leaked. Is this an adjustment I need to make to stop it, or put a new seal on it? The current seal is flexible, but not sure what it is suppose to look like.
Thanks for the input
Bryan
Old Mar 6, 2006 | 02:07 PM
Arek's Avatar
Check this out:http://www.innerbean.com/housecor/su...noise_fix.html
Old Mar 6, 2006 | 02:32 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Originally Posted by Arek
Bah, beat me to it.
Old Mar 6, 2006 | 02:48 PM
bpe383's Avatar
Thanks for the input guys. I've read his site, (good stuff) but the leak is not addressed. It rained today and there was no leaking. My guess is I was to close and blasted the water into the seal, but under normal rain conditions it will be fine. I'm still going to do the adjustment of the roof with the shims, but I have to figure out where the heck to get them for .65 each. I went by my dealer, and they want $8.00 for one, and it's a special order item so I have to buy like a bag of 10.
Old Mar 6, 2006 | 03:03 PM
bpe383's Avatar
O forgot, the parts person at the dealer also told me I didn't/couldn't have a maxima SE because they didn't have sunroofs, nor where they options for that model. He told me that I needed to re-chcek my sticker on the door, or bring the vin # in because he thinks it's a GLE. So, I've now found out my local dealer will be useless in getting parts. Any ideas?
Old Mar 6, 2006 | 05:45 PM
Arek's Avatar
Stay away from that Nissans parts person - his a moron. Yes sunroof is not standard on SE - it's an option but as far as I know 90% of SE Maxima's have it.
Old Mar 8, 2006 | 09:39 AM
cmoore135's Avatar
i have a problem with noise from sun roof unfourtunetly it is because my hood flew back and took out my windshield and sun roof. got new windshield but still looking for new sun roof or glass. any help?
Old Mar 8, 2006 | 09:55 AM
Maxima570's Avatar
WOW hopefully this guy was brand new. It might be tough for a junkyard because the car is so new, try eBay (my favorite). Or it could be that this guy didn't have a clue, and told you the price for some other part that he took it upon himself to assume you meant. Maybe try a different dealership?
Old Mar 8, 2006 | 06:05 PM
Arek's Avatar
You can go to Nissan part department and ask for part number:91249-50J10 (adjusting shim) I belive you will need two of them they like $0.50 each.
Old Mar 9, 2006 | 12:36 AM
acidbbg's Avatar
good info!
Old Mar 9, 2006 | 02:49 AM
SoonerFan's Avatar
Cletus
go beat his @ss.
seems there are a lot of SE that magicaly got sunroofs (like mine!)
Old Mar 23, 2006 | 01:13 AM
scorpion35's Avatar
If you add a shim be careful not to tighten the screw when putting the nut back on. I broke the damn screw and it cost me $500 for a new roof and $200(got the hook up) to put it back on @ the dealer. A .50 cent problem cost me over $700 to fix.
Old Mar 23, 2006 | 12:08 PM
bpe383's Avatar
Update, First I have not gotten around to the shims yet. However the roof does leak. Is this normal? I ask because, there seems to be gutters built into the sunroof frame for draining. Which has me thinking Nissan planned for this item to leak a bit? What are ya'lls thoughts on this? Under normal rain it doesn't appear to leak, but if I wash the car watch out. It's like a waterfall. It does not leak to the point of getting the inside wet, but I can hear it draining out the gutter system in the roof. Do you think the shims/adjustment will help this?
Old Apr 12, 2006 | 08:23 PM
MaximaGT-R's Avatar
I'm a Happy Man!
they should help but i took off my sunroof guard months ago and i never had any leaks neither in the rain nor snow.
Old Apr 12, 2006 | 08:43 PM
spiromax's Avatar
Seoul Man
My sunroof will leak a little if I hit it with high pressure water while washing it or if I commit the ultimate sin of taking my car to one of those automatic car washes with high pressure water jets. It does not leak under normal rainy driving conditions. I think it's just high pressure water that does it.
As for that guy who says the SE can't have a sunroof... I have an SE Titanium Edition with a sunroof. Nissan's "service technicians" and "parts specialists" are notorious for being clueless about Nissans.
Old Sep 16, 2006 | 11:56 AM
RSG's Avatar
RSG
In regards to the shim, how many of these should be installed on the 5th gen? I checked this morning and noticed there are 4 of them on the left side but only 2 on the right!!! Maybe that’s the reason why there is little wind noise when I go above 55mph.
Old Sep 16, 2006 | 06:51 PM
zoutv's Avatar
The air noise does seem to become noticeable at 40 or above for me.....I have a 2000se
Old Sep 16, 2006 | 10:42 PM
RSG's Avatar
RSG
Tilt up the sunroof, step outside the car and look from the side. There you can count the number of shims installed. Please report back if you have 2 or 4, thanks.
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
Unclejunebug
Apr 2, 2016 05:42 AM
jonreidhead
Jan 6, 2016 09:38 AM
