Spark Plug Install Question for 2001
Old Mar 9, 2006 | 11:36 AM
Jopa416's Avatar
I was reading the spark plug installation instructions but they appear to be for 2002 & 2003....does anyone have directions for the 2001 Max. Truthfully the job looks like a nightmare.
Old Mar 9, 2006 | 11:38 AM
MAXRB8's Avatar
02/03 the intake manifold has to be remove PITA, but for your year it's not required, much easier shouldn't need a write up.
Old Mar 9, 2006 | 11:42 AM
Jopa416's Avatar
Thank's for the reply....I would not even attempt the 02- 03 job.
Old Mar 9, 2006 | 02:06 PM
frankd121's Avatar
Here's an excellent write up in the how to section:
http://www.picshed.com/tanman/
The front plugs take 10 minutes to change; the backs are considerably harder. Stretch your back before trying the back ones.
Old Mar 9, 2006 | 02:11 PM
tdashmike's Avatar
I jsut did my spark plugs today. I put some anti-seizing lubricant on the threads, maybe you should do, makes it easier on the threads.
Old Mar 9, 2006 | 03:46 PM
5thgenmaxima's Avatar
Back ones are just about as easy as the fronts, IMO. Cake job. The only thing not listed in the write-up is make to to have a magnet just in case. When I took the middle coil on the back side off I dropped the nut. Easily fixed by using a magnet to pick it up.
Another way to make sure they don't slip off while putting them back on is by putting a napkin between the nut and socket. This takes up the small space between the two and secures the nut inside the socket.
Old Mar 9, 2006 | 06:41 PM
00MaxSE's Avatar
Pointy Elbows
You might get leg cramps when changing the rears. I know I did, as did 97Whtse when I watched him do his. Like they said, get a magnet rod. It helps.
Old Mar 9, 2006 | 07:03 PM
jenk01SE's Avatar
That, plus a long socket extension and you shouldn't have any problems.
Old Mar 10, 2006 | 07:42 AM
Jopa416's Avatar
I appreciate all of the replies and instructions.
This is a great board.
Old Mar 10, 2006 | 09:47 AM
alpinestars™'s Avatar
THIS IS...
Oh wow, the 5.5 gens look hard.
Old Mar 10, 2006 | 11:21 AM
jkayca's Avatar
I don't have any of the tools to do the job. Is it worth it for me to buy them? I'm still on my first set of plugs which have lasted 5 yrs. I'm assuming another set will last another 5. I'm thinking it's pita and it will be almost as cheap to get my local mechanic to do it.
Old Mar 10, 2006 | 11:32 AM
SoonerFan's Avatar
Cletus
owners manual are a wonderful thing...its a nice manual...you know, for owners
jerrod99_se-l
Aug 24, 2015 10:24 AM
Maxboy23
Aug 21, 2015 11:02 AM
Turbobink
Aug 15, 2015 07:20 AM
1992maximase30
Aug 5, 2015 09:27 PM
maxima297
Aug 3, 2015 12:50 PM
