clutch acting funny
Old Mar 10, 2006 | 04:11 AM
Kiosk's Avatar
clutch acting funny
my clutch pedal is getting spongy and front time to time it gets low, engages really low. If I pull it up with my foot it will raise again.....I changed the fluid in the system last year and it looks clean, how can I tell if it is the clutch master or slave cylinder going bad?
Old Mar 10, 2006 | 04:52 AM
Progress's Avatar
It's business time.
My clutch was messed up bad. I have an aftermarket one but I had my mechanic adjust it and it feels better but its still not "good." I really hate my clutch.
Try getting it adjusted and/or bleeding it.
Old Mar 10, 2006 | 05:59 AM
callkiss's Avatar
This very same think happened to me when I had my 97 Maxima, I just installed a stage one clutch. The fix was to get a new clutch pedal line and rebleed the line. Even after that the clutch pedal was installed it still was very stiff because of the stage one clutch, but it played a little better.
Old Mar 10, 2006 | 06:27 AM
Progress's Avatar
It's business time.
Did you install an SS line? What kind of job is that?
Old Mar 14, 2006 | 09:21 AM
maseo77's Avatar
Sounds like your slave cylinder and or master cylinder is failing.
I should know I went through 2 of them in 1 year
Old Mar 14, 2006 | 01:20 PM
Kiosk's Avatar
how do you know if its the slave or the master?
Old Mar 15, 2006 | 10:10 AM
maseo77's Avatar
I never know I just change both to be safe. Whenever my clutch pedal felt different in any way within a week my slave/master cylinder went, happened 2 summers in a row. Its most likely the master cylinder but because the slave is so cheap go ahead and change that too. And bleeding a clutch on a max is murderous.
Old Mar 15, 2006 | 07:04 PM
Kiosk's Avatar
dude you aint kiddin...I had to bleed it a couple years ago when I first got it, and that was one my worst DIY experiences on a car...EVER!
Old Sep 8, 2006 | 04:09 AM
ghettogeek's Avatar
I bled the clutch and had the slave and master cylinders replaced by Nissan. A month later, it is doing the same thing! Could it be anything else?
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
zmcneely13
Sep 26, 2015 02:26 PM
carlosvq30
Sep 26, 2015 09:44 AM
