Resonators
Old Sep 6, 2006 | 04:49 PM
VaporHead
Resonators
I was reading about all the pros/cons of different intakes, no this is not going to be a thread about which intake is better. While reading some threads, I noticed people remove there resonators? Where are these resonators located at? I am looking for pics if you got them. I searched the How-To Stickies along with the How-To's on VQpower.com, but with no luck. I'm looking a deep intake sound, kinda like how a GAB sounds. I did try the GAB mod but my dumbarse can't get the dang coat hanger to hold the filter in right.
Old Sep 6, 2006 | 04:53 PM
Hoooper
the resonator is the peice that the rubber hose off the engine comes into.
Old Sep 6, 2006 | 04:56 PM
NmexMAX's Avatar
dot dot dot ...
Helmholtz resonation is what our particular design is called.
Old Sep 6, 2006 | 06:58 PM
VaporHead
Have you removed this on yours? If so, does it make the intake louder?
Old Sep 6, 2006 | 07:18 PM
NmexMAX's Avatar
dot dot dot ...
Much louder.
Old Sep 7, 2006 | 05:06 AM
KidHauler's Avatar
Are you saying that Helmholtz resonation is used in our cars to deaden intake sound or to improve intake performance?
Also, is HR the purpose of the large white plastic container that is connected to the bottom of the air hose coming in off the intake funnel at the front of the car?
Old Sep 7, 2006 | 06:32 AM
NmexMAX's Avatar
dot dot dot ...
Both, but mainly to utilize mid range power as Z33's do not have this, and my dynos have shown to add a bit extra after 6k RPM w/o it, but a slight non linear curve below that RPM, whereas with it, the curve is very linear and stable.
And I'm quite sure it's only place is in between the MAF and TB.
Old Sep 7, 2006 | 02:21 PM
VaporHead
Does anyone have pics of exactly where this resonator is on a VQ30?
Old Sep 8, 2006 | 05:56 AM
KidHauler's Avatar
I just read through the "coil pack cover" thread and found my resonator answers there. Just read between the flames and you'll find what you need to know.
Link => http://forums.maxima.org/showthread....85823#poststop
That thread just convinced me to stick with the stock air box + K&N for my auto 2k.
Old Sep 8, 2006 | 06:13 AM
95bluse's Avatar
As stated the Helmholtz ddeadens sound & improves low-midrange response. The white container (black on 4th gens)is there to collect water & debris. It does not reduce noise nor improve performance, at least during my tests.
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 4, 2015 06:04 PM
mpbclutch33
Sep 1, 2015 09:24 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
george__
Aug 15, 2015 07:24 PM
