What do you guys think about these 2k/2k1 headlights?
Old Mar 26, 2006 | 08:25 PM
scheibler's Avatar
Originally I was going to get the 02-03 hids and put them on my 2000 gxe, but I can't see spending $600 when I'm only 16 making $8 an hour. I have a white 2000 maxima gxe with tinted windows and black rear 2000 se taillights and have been really interested in these headlights even though they are't HID's, which BTW I don't mind.
http://cgi.ebay.com/ebaymotors/00-03...QQcmdZViewItem
Here are some questions I have:
1-What else will I need to buy to get these headlights installed?
2-Are these built with decent quality(won't leak or fog?)
3-Will light output be just as good or even better then oem?
4-Will the direction/angle of headlights need to be adjusted to view the road the same distances as oem?
5-Any1 have experience with these or pics with them on a 5th gen. max?
6-What are your opinions
Old Mar 26, 2006 | 08:29 PM
Puppetmaster's Avatar
Here's a hint....
http://forums.maxima.org/showthread.php?t=415645
Old Mar 26, 2006 | 08:41 PM
scheibler's Avatar
I just want them for looks, not for the increaded performance of hids. Is the beam pattern the same visibly and atleast as bright as the stock 00 headlights with h1 and h3 halogens?
Old Mar 26, 2006 | 08:42 PM
No. See the links I posted in the thread above.
Old Mar 26, 2006 | 08:47 PM
scheibler's Avatar
damn... looks like I'm either gonna go ahead and mod to 02-03 hids or just get the smoked oem headlights off ebay
Old Mar 26, 2006 | 08:52 PM
MxdOut97's Avatar
why not just do the AE mod and smoke them yourself for free
Old Mar 26, 2006 | 08:53 PM
NYPD-Arnold's Avatar
Z
There's no such thing as a beam pattern with these. In order to have a beam, you need to put out light. =(
Old Mar 26, 2006 | 09:52 PM
MaxBoost925's Avatar
Drug Money
Stock 2K headlights use H4's and fogs use H3's young'n.
Go OEM HID and mod those with DDE's if you want a clean modded look. Don't use these cheap **** things.
Old Mar 26, 2006 | 11:48 PM
AceofSpds's Avatar
wat
What about the ones they sell on SCO are they just as crappy?
Old Mar 27, 2006 | 04:22 AM
scheibler's Avatar
Is there anyone or any site that knows ALL of the parts that I will need to buy for 2k2-2k3 lights to fit on my 00 max gxe? Is there any step by step instructions on how to perform this instillation
sory for all the questions, but I don't have a clue where to start and I am not a donating member to search the forum.
Old Mar 27, 2006 | 01:22 PM
Drug Money
It's all over the forums. Donate some cold hard cash and use the search method.
I'm doing this swap right now as soon as my parts arrive.
Old Mar 28, 2006 | 01:23 PM
seshead's Avatar
yeah...i wanted to get this as well but sincehearing all of this feedback about its crappy output is puttin me on hold...
But.............. they are so beautiful and would look good on the ride. I dont care about the output really.....i mean stock output is not as bright either.....
let m eknow if you go ahead with it....i might buy them at the same time.
Old Mar 28, 2006 | 04:16 PM
Drug Money
do you have ricer blue bulbs in your stock 2000 housing? That could explain poor light output.
Don't do mods mainly for style, do them for functionality first, 2nd comes style.
You can buy HID housings and black them out with DDE's. They'd give off much more light and look better at the same time.
Old Mar 28, 2006 | 04:37 PM
GigEmAgs07's Avatar
okay so i know i'm hijacking a thread, but i can't start new ones yet and i can't find an answer. I have a 2k SE and my rear blinker bulbs are said to be py-21w bulbs? Is there another name for that kinda bulb? like a 31XX or anything like that. I've been lookin at gettin silverstar turn signal bulbs since autobarn has them on sale, but i don't wanna get the fronts without the rears. tia
Old Mar 28, 2006 | 04:40 PM
Drug Money
Aren't they 1156 or 1157?
Old Mar 28, 2006 | 06:30 PM
SuperStasiu's Avatar
You need a wireing kit. Like this one
http://www.courtesyparts.com/Merchan...de=24009-A33HK
Then the headlights and then the wireing instructions which i will galdly sell to you for ONE BILLION MILLION GAZILLION BADZILLION DOLLARS MUAHAHAHAHHAHAHAHAHAHA
Old Mar 28, 2006 | 08:37 PM
GigEmAgs07's Avatar
No. Not on my max at least. Everything i read says that the rear blinkers take 1156 bulbs. However, they do not fit in the socket. The little ***** on the bulbs themselves for 1156 bulbs are on opposite sides of the bulb. For py21w bulbs, the little ***** are closer together than that. Just wondering if there was another name for a py21w bulb... is mine the only max like this?
Old Mar 29, 2006 | 04:49 AM
bigfatty's Avatar
Booyah grandma.... BOOYAH
Here is the 2000 OEM pattern and ebay lights pattern, you tell me.
OEM
EBAY
Buy them, but set aside money for a retrofit. You do a retrofit on these and they will look good and you can actually see the road.
Fat
Old Mar 29, 2006 | 06:46 AM
philzaga's Avatar
Ebay projectors aren't actually that bad. I've gone through 00 OEMs, 2k2 OEMs, and now ebays. In my opinion, the 00's have better output than both the other two. The flaw about the ebay projectors is that the light is not evenly distributed on the ground. The light projected however(brightness), isn't all as bad as most have said it is. It's certainly not HORRIBLE to the point where you can't see at night or anything. As stated above, buy them, save for a retrofit(which would give you the BEST light output above all) and you should be fine.
edit: all of the above are with HIDs of course.
Old Mar 29, 2006 | 06:59 AM
Maxima570's Avatar
I wanted to get the ebay projectors, and then retrofit lexus ls400, or bmw/audi projectors into them. Then I remembered that I don't know how and don't have the money, but it can be done and everything about it would be good. In the future, I'll be reading about this retrofit, and if I can find them cheap, I might work up the courage to start messing with the factory HIDs. If you look around, theres a lot of info about these ebay projectors, and you can really make them nice. Also try HID forums too...
http://www.hidplanet.com/forums/
DZN13
Aug 24, 2015 11:00 AM
maxipower
Aug 21, 2015 11:10 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
Nintensity
Aug 13, 2015 05:41 PM
