Are the 02 and 03 6-speeds intrchangeable.
Mar 27, 2006 | 09:14 PM
I'm thinking about replacing my open diff 6-speed with 3rd gear crunch with a low mile unit with HLSD. Probably in the next few weeks.
If I find a tranny from an 03 will it bolt right in?
Also, how can I confirm that a tranny has HLSD. Is it incoded in the VIN or on the tranny itself?
Mar 27, 2006 | 09:20 PM
I'm pretty sure you can use an 03 trans, afterall, we can even use A34 trannies. In fact, you might even want to look into that, since the gear ratios are better on the A34 6 speed. I haven't done much research on it yet, but I've been told by a reliable source that its a direct bolt on.
IIRC, there is no indication on the housing itself that it is HLSD equipped, you have find out either using the VIN or the transaxle code on the vehicle's firewall. A transaxle code ending in "H" means it has HLSD and ending in "A" means open diff.
Mar 27, 2006 | 09:50 PM
Thanks. I figured it would be.
I'm not familiar with the A34 tranny though. Which car is that from?
Mar 27, 2006 | 09:53 PM
A34 = 04-06 Maximas
It is supposed to have a lower final drive and better 3rd gear synchro.
Mar 27, 2006 | 10:03 PM
I'd go a34 tranny anyday...you can pick up a brand new unit from Nissan for $1,776.65....not sure how much they'd charge you for shipping though...but it does come with HLSD already! not too shabby for a brand new unit ain't it?
Mar 28, 2006 | 04:41 AM
Just having the HLSD equipped tranny may not solve the 3rd gear grind issue. Since it is the synchro that's the issue, you may still have the problem with the 03 tranny.
Mar 28, 2006 | 07:27 AM
there is a 6-speed on ebay right now has 1.5 hours left going for $350.
Mar 28, 2006 | 08:53 AM
Shoot!!. I just cought the last 50 seconds of the auction. Not enough time to check it out.
I think I've found one but the trans code ends in a 0. It's from an 04 car. Are the trans codes different on the A34?
Mar 28, 2006 | 10:03 AM
if your going to exchange from the sounds of it might as well go with the a34 tranny. Im thinking thats what im going to do in a while
