Going to by 5th gen in a few weeks and I have some questions
I posted awhile back looking for opinions about 4th and 5th gens and you guys persuaded to me to go with the 5th gen
. I just have a couple questions about stuff before I pick one up:
What should I make sure is working properly before buying?
How hard are fogs to install on 5th gens that don't come with them?
Do you need spacers for 18x8 inch rims with tires of 235/18/40?
.....I thought I had more questions but I am having a mind blank right now haha
I'll post more later. Also, stickies FTW
![Sad Dance](https://maxima.org/forums/images/smilies/hs.gif)
![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
2.) If you get the right offset, then you don't need spacers. Just get wheels with a correct offset and you'll be fine.
I'm only gonna buy from a dealer, but I will make sure to get the stuff checked that you guys have listed off. About the coils; what are the grey spots all about?
Most of the 5th gens I have seen around here for sale have to plastic vent things in for fogs so I want to replace those unless I get one that already comes with them.
As for the wheels, I already have the rims and tires so I guess we will have to wait and see if they fit ok
Arron, if I have some time and you want, I can go with you or stop by the dealer before you buy to give the car a once over.
Taitor![Stick Out Tongue](https://maxima.org/forums/images/smilies/tongue.gif)
btw, go for an SE if you can. They have fogs from the factory, cooler looking gauges (IMHO), slightly sportier ride, etc. Great choice going for a 5th gen, it's what I would do![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
The wheels depend on the offset but I don't think you will have a problem but not certain on that.
Taitor
cool I'll let you know when I find one
don't know if I can get an SE, but I'll do my best
I will still be satisified if it's not. It's all about the 00 5th gen at this point
![doublethumbsup](https://maxima.org/forums/images/smilies/dblthumb2.gif)
Some 5th generations have the faulty precats and I've know a few dealers to reset the ecu so codes are not thrown when the customer test drives the car. After about 100 miles or so the SES light would pop up. So maybe you might want to question the dealer on possibilty of precat failure.
Installing the fogs is very very easy, specially if you get the factory kit, which comes with everything you need. It costs about $150 or less. Here is a link to the installation instruction at courtesy nissan of texas (courtesyparts.com)...
http://www.courtesyparts.com/instruc...ghtkit_01.html
Here's the general link to the kit from the same place..
http://www.courtesyparts.com/Merchan...de=B61E0-00001
there are many things to check, id do a very thorogh check of a car before buying. invest in a $45 ODBII code reader and check the car. check make sure VIAS is working, push the car on the test drive to redline a few times, make sure it doesnt die off at 5500rpms. check for leaks between engine/tranny. make sure tranny shifts smooth (auto) make sure clutch is ok if 5spd, check rotors with some braking tests, take out a few spark plugs and check for oil on them check exhaust for holes as they are very prone on 5th gens, especially etween b pipe and muffler. thats all i can think of right now, hope this helps.
Finkle
09-27-2015 09:53 PM
scarletsosa
08-17-2015 09:09 PM
