Glowing Red Rotors
Old Apr 2, 2006 | 03:04 PM
2kSC's Avatar
Glowing Red Rotors
Last night (after 10 minutes of driving) I noticed that my rotor overheated and turned red. Today it seems to be fine. My guess is that my caliper is locking-up spontaneously.
Did anybody experience this? If so, what needs to be replaces and how much did it cost? All input is appreciated….
Old Apr 2, 2006 | 03:19 PM
BRINKLEY's Avatar
I would say your your pad is rubbing.. just a guess though.
Old Apr 2, 2006 | 03:23 PM
FrostMaxima's Avatar
sounds like a seized caliper, just get a new caliper to play it safe!
Old Apr 2, 2006 | 03:40 PM
M1RAG3's Avatar
Check your emergency brake was all the way in the DOWN (disengaged) position, even if it was UP just a bit it may have caused friction with the rear pads, which over the time of the drive, caused them to heat up quite a bit.
Old Apr 2, 2006 | 03:46 PM
nicks79's Avatar
should have taken a picture, that one would be worth alot.
Old Apr 2, 2006 | 03:53 PM
spark plugs.'s Avatar
Hi, I drive a Maxima.
was it on the front or back rotor?
Old Apr 2, 2006 | 04:01 PM
2kSC's Avatar
it was a rear rotor...does anybody know how much a new caliper would cost?
Old Apr 2, 2006 | 04:07 PM
why would you buy a new calipers? get rebuilt ones from your local autoparts store...but i'd replace them asap.
Old Apr 2, 2006 | 05:56 PM
Hoooper
make sure theyre seized before you replace them. the same thing happened to me last night and all i needed to do was fix the adjustment on the brake light sensor and cruise control sensor sitting on the back of the brake pedal, the sensors were holding the brake on. could be your ebrake out of adjustment too. just make sure they actually are seized before you go replacing them
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
Socalstillen
Sep 26, 2015 12:01 PM
