2002 DriverSide Automatic window problems
Old Apr 2, 2006 | 05:06 PM
NismoGTR's Avatar
I have a 2002 and when i use the automatic up button on my driver side window, it goes all the way up but then goes back down about 25%. I can close it if i dont use the auto but y does it happen. My passenger side works perfectly. Does any1 have an idea?
Old Apr 2, 2006 | 05:17 PM
boondoxmax's Avatar
mine did that this weekend and for some reason the next day it was fine. Don't know what caused it but i was a little worried.
Old Apr 2, 2006 | 05:18 PM
NismoGTR's Avatar
Mine been doing this for a while
Old Apr 2, 2006 | 05:28 PM
Dust N Bones's Avatar
It's a common problem with 5.5 gens. But it's an easy fix, I fixed mine in less than 10 minutes. Instructions...http://forums.maxima.org/showpost.ph...64&postcount=3
Old Apr 2, 2006 | 05:40 PM
KCMC582's Avatar
yeah, this is pretty common, the first thing you should try is this reset. if this doesnt work tho, like it didnt for me, it might be the window motor that needs to be replaced. but try the rest first.
Old Apr 2, 2006 | 05:53 PM
shurik's Avatar
Yeah I have the same problem. I need to do this fix procedure as well, sounds pretty easy.
BTW Here's the thread I had about this a couple weeks ago...You're not the one with this annoying problem bro. Sometimes the problem goes away, but then it comes back...wierd!!!
http://forums.maxima.org/showthread.php?t=459599
Old Apr 9, 2006 | 09:05 AM
shurik's Avatar
Well tried doing this procedure to fix it and it worked. No more rolling windows by it self. haha
The Frye
Feb 3, 2019 08:34 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
Justin Kroll
Sep 2, 2015 11:06 AM
