For those with the ebay projector headlights
The dealers say we need HB3 and HB4 bulbs to replace these lights but why are these bulbs so small compared to the HB3 and HB4? and also does anyone know how to install them because all I see is a long white wire that is attached to a small lightbulb...no plugs or anything
the ebay version uses 9005 and 9006 bulbs....but there is no plug anywhere for me to connect the new light bulbs....the old light bulbs only had a small bulb attached to a long white string
It depends, sometimes the dealers give you the light bulb and harness, most of the time they don't. if you bought the cheapest ones on ebay then no, they probably didn't come with the harness. that is why you should ask them questions before you buy or else you'll get
the harnesses are simple to make once you studied it.....go to HIDplanet.com hrmm or you should do what roy did, http://www.cardomain.com/ride/578450/1
for the harness....you have to buy the male counterpart for the headlights and then rewire the lights to that your high will turn on to your highs and lows on lows the DDE (angel eyes) you can wire wit your parking or separately wit a switch to the dash
the parking and turn signal you would also need a male counter part of the bulb
another thing....who did you buy it from?
i'm thinkin of buying one too but ummm looks like none of them sell it plug and play....or i seen one but idk, he is not answering my questions
or you can buy a harness premade
http://www.suvlights.com/product_inf...roducts_id=112
or learn how to make your own at
http://www.hidplanet.com/forums/view...ght=conversion
to get the male connectors for the H4/9003 or the H3 for your fogs or whatever
http://www.suvlights.com/product_inf...roducts_id=215
Now for your turn signal well.....idk? LOL you might wanna as Dr Roy....but becareful he makes some sick ****....jus look at his led tail lights!
good luck
good luck
http://cgi.ebay.com/ebaymotors/9005-...QQcmdZViewItem
would these work or do you need relays and all that stuff
About poor light output hmmm I think i can prove people wrong. I have the black ebay projectors on my car.
I was going to do a retro but I was too scared to open the lights up so I just used a 8000K HID H3 kit. Put the bulbs in. The light output was bad at first so I played around with the **** behind the headlight. It looked like there was no difference since I had to take out the headlight to do it but believe me my headlights are bright as hell now. The only setback is that the cutoff didnt come out even plus the cutoff is not as beautiful as the Audis and BMWs.
I will take pictures and post them as soon as I get a chance.
DOnt' Blind PEOPLE!!!!
That **** behind the headlight adjusts level of the beams. You may have adjusted the levels by milimeters. Several milimeters may not look like much 5-15ft away, but 100 -150 yard may look like the beams are a little high or a little low.
Putting HIDs may have been a simple fix, but put yourself in the other person shoes and see how bad the glare is if you were an oncoming driver.
Quick reminder for anyone trying to get these headlights "the low beam shuts off when you put on the high beam so this might be a concern for those trying to put HIDs in the projectors.
is there a way to not turn off the low beams?
Question for everyone. Has anyone installed these headlights using 02 harness? And does the high beam turn on with the low beam?
I have 2k3 maxima. Got excited by the black projectors on ebay. I sold my HID head lights. Now the Projectors arent bright enough at night. I changed the h3 bulbs to 4300 k something. How can I make them blue . I was told HID wont work with the projectors. Please help
maxima@usa.com
maxima@usa.com
Word on the board is that the HID's will work with projectors.. just not those. Well, you wont get a very good beam pattern until you retrofit those ***** with another projector. Do a search and you'll find plenty on retrofits around here. As for a blue beam, your going to have to go UP on the Kelvin scale, like a 8000K or so if you want Blue.
maxima@usa.com
maxima@usa.com
Let me post pictures to make you believe.
litch
123
Jan 4, 2024 07:01 PM
doctorpullit
Oct 28, 2019 10:58 PM
magiconthetire
Oct 26, 2015 09:03 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
where do i get the harness...what kind are they..? thanks!
