quiet clunking noise/ when moving wheel
Old 04-06-2006 | 06:58 PM
ornery1's Avatar
i put h&r and tokico blues on my 2k se a few weeks ago with absolute no moaning,groaning,creaking,clunking whatsoever. now last nite i have noticed a quiet but audiable noise( you know when its your car) when i am going slow and i move the wheel back and forth. sounds like it is coming from passenger side front. my friend said possible rack and pinion bushings?? any clues? i am also guessing end links, have 66k on it.
Old 04-06-2006 | 09:22 PM
ornery1's Avatar
anyone?????????????
Old 04-07-2006 | 10:05 AM
Barc's Avatar
May be that the mid steering shaft has some slop in it. If it did, you should be able to turn the wheel a little before the shaft "catches" and starts turning the wheels. When it does finally "catch" you should feel a bump or a clunk or something. Or it could be something entirely different...
Edit... just noticed that it is coming from the passenger side... Have someone (or multiple someones) outside the car listen in a quite parking lot a few feet away from your car to determine more of where it's coming from. Does it clunk when going over bumps as well or just when you turn the wheel?
Old 04-07-2006 | 11:28 AM
MaxHind's Avatar
CV Joints? when they get old and dirty they make noise. Mine are worn.... :-(
Old 04-07-2006 | 11:53 AM
rkyat's Avatar
mine make the same exact noise in the same spot at stop/low speed turns. it all started after i put in my h-techs/gr-2s. i never got it checked out, i will soon tho.
Old 04-07-2006 | 12:29 PM
ornery1's Avatar
i dont think bumps make a difference. i only hear it going slow, at faster speeds i can feel it in the car.
Old 04-07-2006 | 07:24 PM
ornery1's Avatar
now it does it on bumpy rough roard, but not on dips or speed bumps.. wtf?
Old 04-08-2006 | 01:52 PM
Barc's Avatar
The usual suspects are sway bar end links and strut issues for that sort of thing.
Old 04-08-2006 | 06:29 PM
MIXXMAX's Avatar
Possible noise could be strut bearings???
Old 04-09-2006 | 06:41 PM
Teufelhunden's Avatar
sound like sway bar links. does it sound like its coming from the wheels or the strut? does it make the noise on smooth road or just in bumps? sounds like somethings loose? be a little bit more descriptive. if its what you have described, then its definately sway bar links. mine did that, and its cheap and easy to fix.
Old 04-09-2006 | 07:56 PM
ornery1's Avatar
it does it now on bumpy roads, but you have to be going slow to hear it. if it was not my car the next man to drive it would probably not hear or feel it, but when you drive the car every day and you develope a new noise you know it! it doesnt do it on speed bumps and if i bounce the car with help of friends i dont hear it either.
matts95max
05-20-2024 02:16 AM
captchaos
03-15-2016 01:18 PM
alahjahwan09
18
09-21-2015 10:12 PM
Hdnseek
09-09-2015 06:55 AM
jfl330
09-04-2015 02:44 PM
