1.5 ton Jack is that pushing it?
Old Apr 12, 2006 | 09:43 AM
Battle Max's Avatar
Sears has a really good deal on a 1.5 racing jack and i know that our car is a few hundred pounds over the 3k mark. Is it pushing it or will i be okay?
Thanks!
Old Apr 12, 2006 | 10:24 AM
Larrio's Avatar
The Definitive AE Master
Its a few hundred pounds over in TOTAL weight. Since you'll only be jacking up the front/rear or left/right, you'll be fine.
Given roughly 60/40 weight distribution and 3300 lbs vehicle weight, the distribution will be 1980 F/1320 R
Old Apr 12, 2006 | 10:25 AM
surfman21's Avatar
Thanks!
why would you even risk it?????????? imagine the regret if your car fell....
Old Apr 12, 2006 | 10:33 AM
nismo0604's Avatar
yes it is fine to lift it up with a 1.5 ton jack, but do not leave it up just on the jack, put it on stands, because the jack could start leaking the hydraulic fluid and almost crush you (speaking from experience)
Old Apr 12, 2006 | 10:34 AM
BumpnMaxima's Avatar
thats perfectly fine. like previously stated, unless you can someone jack up the entire car from one point
Old Apr 12, 2006 | 10:36 AM
Kevlo911's Avatar
Kevlo for President
Do not read any other post than this. This is all you need to know.
Old Apr 12, 2006 | 11:05 AM
Battle Max's Avatar
Thanks I know jack stands are a must...
Old Apr 12, 2006 | 11:46 AM
Love_00_Max's Avatar
Thanks!
Car weight is as follows
Total weight = 4400 pounds
Front weight = 2800 pounds
Back weight = 1600 pounds
A jack should atleast be twice in tonage than what the weight of the vehicle.
I would go nothing below 3 Ton (6000 pounds, for some reason the jacks calculate 1T = 2000 pounds, but actually 1T = 2200 pounds).
FYI, I have a Torin 3T jack -- feels safe!!!
Old Apr 12, 2006 | 12:19 PM
vsamoylov
your car will flip over when you jack it up with that jack
Old Apr 12, 2006 | 12:30 PM
jimmycapp's Avatar
I have the craftsman 1.5 ton "race" jack and It works just fine, unless you want to jack it up at the centroid then you will be fine.
and 4400Lbs must be a missprint.
James
Old Apr 12, 2006 | 12:35 PM
bigEL's Avatar
What are you carrying in your car?!
Old Apr 12, 2006 | 12:49 PM
XyNoix-HIC's Avatar
an extra ton of ricer stuff....LOL jus joke
Hoooper
WHAT??? no thats not a missprint, check out the f/r, 2800+1600=4400...must have a few dead bodies in there.
PS: im pretty sure 1T really does equal 2000 lbs, at least thats what a physics textbook will tell you.
In response to the question, you should be fine, the first post sums it up. you will never actually jack up the whole 3300 at one time, always distributed partially to the back or front wheels that are still on the ground.
PS: if the front were 1200 lbs heavier that the back you might flip over on speed bumps.
4400 lbs FTL
Old Apr 12, 2006 | 12:53 PM
chr0nos's Avatar
1 tonn is more than 2000 pounds. 1 pound is .48 of a kilogram (somewhere around there...)
Old Apr 12, 2006 | 12:58 PM
1 Kg = 2.2 pounds
1 Ton = 1000 Kg.
So, 1T = 2200 pounds.
Now, 4400 pounds is what is written on the driver side door. Check before barking.
Old Apr 12, 2006 | 01:04 PM
Hoooper
1T is a US measurement, not a metric measurement, so it has no relation to Kilogram besides having some conversion factor.
Trust me, your car is not 4400 lbs, it might say 3400 lbs and thats the GVWR. the only way its 4400 is if its fully loaded with people and has lead in the trunk, do you jack your car up while you and your family/friends are in the car?
Old Apr 12, 2006 | 01:14 PM
OK, I ran down to the parking lot and this is what I see
Total GVWR : 4333
Front GVWR : 2333 (give or take some pounds)
Rear GVWR : 2000
Old Apr 12, 2006 | 01:17 PM
Kevlo911's Avatar
Kevlo for President
That is the maximum wieght the car can handle IIRC.
Old Apr 12, 2006 | 01:22 PM
SPiG's Avatar
SomePsychoGuy
Originally Posted by google conversion
1 short ton = 2 000 pounds
1 metric ton = 2 204.62262 pounds
A maxima cannot weight over 4000lbs without a lot of help. I have seen turbo 4th gen below 2900 without driver. 3000lbs is the given average for a 4th gen and 3200lbs for 5th and 3rd gens.
As stated before, it should be fine to jack it up, but put it on jack stands and don't leave the weight on the jack.
Old Apr 12, 2006 | 01:24 PM
SPiG's Avatar
SomePsychoGuy
GVWR = Gross Vehicle Weight Rating
It's how much weight your vehicle is designed to carry. The GVWR includes the net weight of the vehicle, plus the weight of passengers, fuel, cargo and any accessories added to the vehicle after purchase. The GVWR is a safety standard used to prevent overloading.
Old Apr 12, 2006 | 01:26 PM
jimmycapp's Avatar
Gross vehicle weight. I.E. 5 people of average weight + cargo
Bark,
James
Battle Max's Avatar
Car and driver list the curb weight at around 3200 pounds.
Old Apr 12, 2006 | 01:29 PM
I stand corrected on my understanding of weight of car but I did buy the jack based on what was written on the driver's side door.
GVWR - Acronym for Gross Vehicle Weight Rating. This information is provided by the vehicle manufacturer and is located on a tag generally found on the driver side door jamb. It tells you how much total weight, including occupants, fuel, bed load, etc., the vehicle is rated to carry.
Old Apr 12, 2006 | 01:31 PM
Larrio's Avatar
4000+ lbs maxima?
Old Apr 12, 2006 | 01:53 PM
Mass_Media's Avatar
Mass_Media™
He MuSt Be MaD tUcKiN wItH 24's y0!!!!!11
Back to the original post. Like everyone has said go with the 1.5 ton. That will be more than enough to handle lifting the car
Old Apr 12, 2006 | 02:17 PM
CCS2k1Max's Avatar
Thanks!
What's a really good deal? I may pick one up myself for my much less than two ton max.
Old Apr 12, 2006 | 02:20 PM
Fr33way™'s Avatar
Wild for Width
I have a 3.5ton jack, and work with a smile on my face.
Old Apr 12, 2006 | 02:21 PM
Battle Max's Avatar
Sears has the 1.5 alum. racing jack for 90 bucks at my local sears until 4/15. I see that they are selling it on sears website for 99.99 which is still a good deal.
Old Apr 12, 2006 | 02:25 PM
CCS2k1Max's Avatar
$90 is pretty good, especially if you don't have to pay shipping. I'll check my local Sears Grand and see if they have the same deal.
Old Apr 12, 2006 | 02:33 PM
Larrio's Avatar
Just a note about the aluminum racing jack.... it doesn't lift as high as a conventional jack since it starts off at a lower height. Something you may want to consider down the line if you need more access underneath
Old Apr 12, 2006 | 02:50 PM
sciff5's Avatar
5.5gen maxes are 3200 and change
I35s are 3300 and change
I got a 2 or 3 ton jack from walmart for like 21$. Even if the thing breaks I dont care. Although the metal shaft on that you hold onto to pump the jack (man this is sounding phallic) is pretty weak and when I am lifting heavier vehicles like my dads escalade it starts to bend a little. Ohh well if that breaks I will just replace it with a solid steel bar. But even for being 21 bucks it extends high enough to pick the front wheels of my dads escalade up off the ground.
Old Apr 12, 2006 | 03:09 PM
vsamoylov
true but most people here are soo low that a regular jack wont fit. if i try to jack my car up with a regular jack that has the saddle at a normal height, i need to lift the side of the car first and then the jack will fit under the front of the car.
Old Apr 12, 2006 | 03:42 PM
This is a great set -- 3 T Craftsman floor jack, stands and creeper set for $129. I have seen this on sale for $99 too..
FYI, jacks comes on and off on sale, just have to keep looking. I have had good success with their online catalog compared to the ones in sears has in their stores.
http://www.sears.com/sr/javasr/produ...id=00950188000
Old Apr 12, 2006 | 04:00 PM
Hoooper
thats true, my car's not even lowered and i have to go in from the wheel well or the jack hits on my side skirts.
Old Apr 12, 2006 | 04:42 PM
The Law's Avatar
I R The Law
well duh you have side skirts that put about 1 in lower compared to a car with no side skirts....
Old Apr 12, 2006 | 05:12 PM
Bluesbrekr's Avatar
Doctorate in Detailing
I have the Sears 1.5 ton racing jack, too. Got it at Christmas. $99 at my local store. $90 is even better. BTW, it fine for lifting the Max.
Old Apr 12, 2006 | 09:37 PM
spiromax's Avatar
Seoul Man
First of all...
Those of you who are arguing about the measure of a ton are actually both right. A "long ton" in the UK/Imperial system was 2240 pounds (1016.05 kg). The UK and most other countries that used the Imperial system of measurement now use the metric tonne (1000 kg or 2204.62 pounds) as the only form of "ton" for legal trade. There's less than a 2% difference between the old Imperial ton and the metric tonne, so the transition was easy for nations that used the Imperial system.
The "short ton" used in America is exactly 2000 pounds (907.18 kg). This definition of a ton was also applied to the "Harbour ton" in South Africa. Both the "short ton" and the "long ton" mentioned above are composed of twenty "hundredweights." The difference between them is that the short ton is based on twenty true hundredweights of 100 pounds each, while the crazy British based the long ton on twenty hundredweights that each weighed 112 pounds. The metric tonne, of course, is not related to pounds or hundredweights. It is simply equal to 1000 kg, which just happens to be very close to the same weight as a long ton.
Second...
If you want a jack with a good lift range but your car is too low to accomodate a big jack, there is an easy solution. I have a 3 ton Torin SUV jack with a lift range of up to 20 inches. Obviously, this is a big jack that wasn't meant to lift a family sedan, especially not a lowered one.
I solve the problem by driving up on my ramps then using my jack. If you already have ramps (and you should if you do your own oil changes), then this is a fast and easy solution to allow you to use a jack with a good lift range. If you don't have ramps yet... get some. They're cheap, and they can be faster and safer to use for jobs that don't require your wheels to be off the ground (like oil changes).
Old Apr 13, 2006 | 07:43 AM
Larrio's Avatar
Yes, I'm well aware of this considering that my car is low and I have the craftsman aluminum jack.
Its more feasible to drive it onto ramps and use a conventional jack for more extensive work when I need more room
Old Apr 13, 2006 | 10:18 AM
irish44j's Avatar
retired moderator
Thanks!
My Sears race jack is a 2 ton.....aluminum. Nice and lightweight, and lifts FAST. Didn't know they made a 1.5 ton race jack
Old Apr 13, 2006 | 10:33 AM
Larrio's Avatar
The 2 ton one is for the rich ppl
The 1.5 ton one looks exactly the same but its always on-sale
