2003 NISSAN MAXIMA SE Hypergrounding kit PowerPoint Presentation.
I'm kinda confused a little. On slide 18 and 21 on the updated powerpoint, it states ground #6 goes to #8 (NEGATIVE TERMINAL) but on slide 25 you show ground #8 as being the (ground behind the battery tray), and #9 as the negative terminal ground. So would slide 20 be from #7 ground to the negative terminal or the ground behind the battery tray? I think it's from slide 20 on up is where you'll probably have to clarify the ground points between 8 and 9. By the way thanks for taking the time to make this powerpoint.
Originally Posted by My_first_maxima
My wife thought I was doing way to much work for just a grounding kit............ but HEY, I enjoy doing things like that.
Propz on doing the presentation though. Good work.
Good Catch!
Also, The slide shows the ground wire that goes from #7 (engine ground) to #8 chassis ground behind battery tray. It just shows how the ends of the grounding wire should look with the 1/4 terminal ring and the 3/8 terminal ring.
Thank you for pointing that out.
BTW, you can download the Updated slides with this correction. Just use the signature link.
Originally Posted by Deckdout2
Can you direct me to the slides that tell me "The Big 3" connections?
preesh...
preesh...
http://download.yousendit.com/74C53CA3270A8825
The Alternator is on Slide 14
The Alternator to the engine ground is on slide 15 and 17
The Enigine ground is on slide 19, 20, and 22
The Transmission ground is on slide 28, 29, 30
Hope that helps you out.
Does anyone have this done for a VQ30? If so i'd love to see some grounding points. I've been thinking about doing this to my 2000 I30, but i can't seem to rule out which grounds are where. Any help as to this would be appreciated. By the way, great presentation,i hope we see more of these interactive 21st century presentations that we can easily find and have available.
http://www.cardomain.com/ride/442543/16
hahaha thanks alot man, yeah, i try to go through the FAQs as much as possible, it's just i've got the fifth gen VQ in my 2000 I30 which i know isn't much different but i don't really go to the 4th gen forums. I'll start doin that thanks.
I have been getting emails about sending the PP slides. Right now the bottom link in my signatures still works. I try to update the link every weekend because it expires every 7 days. (If someone knows of an easier way to do this please let me know)
But if it does expire just shoot me an email and I will get it too you.
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
julian888
Aug 6, 2015 04:39 AM
(Fatmat on the rear deck helps for that one)
