A question about angel eyes ***PICS***
Old Apr 14, 2006 | 10:26 PM
kbohip's Avatar
I got my replacement ring tonight and put it in. The install went fine and when I turned it on it looked beautiful. The ring was the exact same brightness as the other ones and I was quite happy. I drove somewhere for about half an hour and came home. Later I went out to the garage to show someone my angel eyes and I see this:
I tried hooking up the ring to the other set of wires on the ballast and also unplugging the other ring to see if the bad one got any brighter. It didn't help. I really hope I don't have to pop open the headlight again.
Old Apr 15, 2006 | 06:29 AM
misiek's Avatar
i think you have a bunch of bad news coming your way... sorry man
Old Apr 15, 2006 | 06:52 AM
Park2670's Avatar
The Ultimate Driving Machine
Mine always did that when it was cold, or there was water in the ballast... Hopefully you can figure it out. If not you are going to be a pro at opening up your headlights.
Old Apr 15, 2006 | 08:43 AM
Igor911's Avatar
Hardwire the connectors together instead of using those plug-in tabs. That will stop your issue from happening
Old Apr 15, 2006 | 07:24 PM
kbohip's Avatar
Well, I've tried everything including soldering the wires, trying different grounds, and changing the wires on the ballast. It didn't help at all and as of tonight the ring only has a faint glow on the upper left side. It's dead.
Old Apr 16, 2006 | 12:35 PM
03MajesticMax's Avatar
Shift_MajesticFemale
Sounds like it is time for another replacement ring...
Did you try witching the ballast?? Try the one from the driver's side... then you will be sure if it is the ring or ballast.
Old Apr 16, 2006 | 12:43 PM
Deckdout2's Avatar
Play with my balls
i think i'm on my 9th set now (rings) and 2nd set of ballest, and not to jinx myself i hope this will be it for quite a while.
Unclejunebug
Apr 2, 2016 05:42 AM
BobTX10
Oct 7, 2015 08:43 AM
Socalstillen
Sep 26, 2015 12:01 PM
