bad habit- breaking keys and remotes..
Ok, I have a bad habit of throwing my keys and because of that I have broken 2 remotes and 2 keys. The keys and remotes still work, but the plastic where they connect to a key ring has busted. I know i need to change my ways, but what are my options- I really like the remote and having a key that won't open the trunk is very inconvienient. I have heard you can get the remotes off ebay and reprogram yourself... is this true? A key isnt that big of a deal, but what are my options? The main thing i need is a working remote that I can put on my key ring.
Yeah, buy the remotes on Ebay. The most important thing is that you buy the remote that matches your "FCC ID" and "P/N" on your existing remote. I have bought a few with different numbers and when I programmed it, it didn't work at all times. The hazard lamps kept flashing like crazy at times. There's a guy on Ebay that sells brand new ones for cheap...around $35.00 or so. Good luck!
go to www.carandtruckremotes.com i got 2 sets of remotes with programing for i think $35,$40 good deal and they work
This is true I just order a remote and a programing from ebay for a remote wholesalers. I got the remote new in box with a sheet of programming instructions that the dealership performs. If I remember right how you program is
1.) Get in the car
2.) Lock doors with Powerlock
3.) Insert Key 6times and remove it totally from ignition in seven seconds
4.) Then the flashers shoudl blink twice signaling that the programing mode has been entered.
5.) The key should be in the ignition at this point and turn to the ACC position.
6.) Click any button on the remote once. Then unlock the door and open and close the door to finalize programming process.
Hope this helps this works on used remotes as well. But as previously stated make sure remote and fcc codes match your car.
1.) Get in the car
1.) Get in the car
1.) Get in the car
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
"Duct tape" I broke my key too... They are too expensive... lol
