Headlight acting up...
Old Apr 24, 2006 | 05:10 AM
MaxVice4's Avatar
My right headlight wont turn on until I punch it I tried takin git out and putting it back in... It used to tak one swift punch but now it takes 2 or 3... whats the problem????
Old Apr 24, 2006 | 06:45 AM
MIXXMAX's Avatar
Sounds like the bulb isn't seating right in the socket and is losing ground connection. Did you try swapping the light bulb from the other side and see if the problem still prevails? Or maybe the bulb is starting to go bad? Also, check the wires going to the headlight and see if there are any loose connections.
Old Apr 24, 2006 | 07:20 AM
TXT-1's Avatar
Try backhanding it....
Old Apr 24, 2006 | 08:00 AM
Nakulbhatt87's Avatar
it seems like a problem i used to have....my solution: rewire some "high temperature" sockets from advanced auto or wwhatever and make some good connections, soldering would be the best, but be sure to heat shrink or tape it. Or you can use quick connects not a bad idea but you might have some issues later as they age because the stock harness is a different gauge of thickness than the "high temperature" sockets. My suggestion is to ground the new wire on the chasis while youre at it, this will improve your headlamps performance.
Old Apr 24, 2006 | 09:33 AM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
i had that issue with my 2k2-3 headlights.... i had bad grounds... mite be suttin u wanna check out? and my friend had the same problem on his celica... he had to hit it for it to work... ended up being that his socket was burned slightly due to the aftermarket light bulbs...
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
