A/T oil change....???
Old Apr 25, 2006 | 10:20 AM
ikalinin's Avatar
46k on my car, am i due?
When did you guys change your A/T fluid? When is is recommended?
Old Apr 25, 2006 | 10:23 AM
alpinestars™'s Avatar
THIS IS...
Not really until 60K but since you are thinking about it you might as well. I recommend AMSOIL ATF. Ask almost any .orger they will tell ya the same.
I changed my fluid at about 52K. I noticed way smoother shifting with AMSOIL. My 2 cents.
Old Apr 25, 2006 | 10:25 AM
03maxima1's Avatar
I thought Nissan recomends every 30,000-35,000. By the way, you posted in the wrong section.
Old Apr 25, 2006 | 10:31 AM
MIXXMAX's Avatar
Depends on when it was changed last (unless it was changed around 16K miles, which I doubt). Yeah, Nissan recommends every 30K or so. The more mileage added on the car, it's highly recommended for a flush as well.
Old Apr 25, 2006 | 10:53 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i change mine as close to every 30k as i can get along with running a cooler and using mobil 1 atf.
Old Apr 25, 2006 | 11:00 AM
igzy's Avatar
I Know Kwaliti
I drain and fill mine with Mobil1 (~1 qt, i.e. 4 liters) every 20K and I'm running an oil-cooler too...
Old Apr 26, 2006 | 09:14 PM
Murat's Avatar
In the manual of my car (Maxima, 2001, VQ30DE) it is mentioned: To change ATF after 40K km or once in 2 years.
Old Apr 27, 2006 | 05:49 AM
UGAd13's Avatar
Everything you ever wanted to know about ATF.
http://forums.maxima.org/showthread.php?t=149056
Old Apr 27, 2006 | 06:39 AM
Spin20's Avatar
Is the mobil 1 ATF synthetic?
Old Apr 27, 2006 | 06:56 AM
SoonerFan's Avatar
Cletus
all ATF is synthetic. thats why its "fluid" and not "oil"
Old Apr 27, 2006 | 07:05 AM
Spin20's Avatar
So would I have to convert my trans to synthetic like I would have to do for engine oil?
Old Apr 27, 2006 | 07:56 AM
shurik's Avatar
And the shops like "Jiffy Lube" suppose to change it for you, right? Do they choose their own fluid, or you can buy your own???
Old Apr 27, 2006 | 08:19 AM
UGAd13's Avatar
Buy your own and change it yourself. It is Really easy. It's just like changing your oil, minus the filter.
Old Apr 27, 2006 | 08:46 AM
whazzzzuup's Avatar
If you drive hard, then it is better to change it more often. I change mine every 5 oil changes.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
