How VIA (Nissan Variable Intake System - NVIS) Works
Found this on Nissan website that 5th Gen (2K/2K1) owners may appreciate. It shows an animated view of how VIA/VIS operates. I just verified the link and it works well:
http://www.nissanusa.com/video/vehic...iable_inta.swf
Mods - there is a link to something that is supposed to show something similar in How-to sticky but it does not work any more...
How do you figure that? 2K/2K1 VIA works on the same principle, i.e. an additional intake air passage opening at 5K RPM and sucking in more air regardless of how the sketch looks... I guess I should have stated it is for all gens >5th?
OK so how can a 02 owner such as myself tell if the flap is opening/working?
I ask because at 5000RPM as in the demo it shows the flap opening. Which means you should feels/hear, or something different with regard to the power at that level. On my car it seems to really stop pulling hard at that point, leading me to think the flap is failing to open, and the engine starving for air. It seems as though it takes for ever to get from 4500RPM to 6000RPM. I mean forever. This is while in second gear 6spd.
Originally Posted by Metal Maxima
Damn, he's in 4th gear only doing 45mph after near-redlining each shift? Someones car is fuxor3d!
Good find though, igzy
Originally Posted by nismology
Not quite. The DE-K VI is nothing like that animation in concept or execution.
On 2K/2K1 engine, air intake works almost exactly the way that the animation shows. There are two air passages in the intake of which one is closed by a flap (that is in on a rod in line with other cylinders and controlled by the actuator) when the engine runs under 5K RPM. 5K to redline the flap opens and more air enters as it goes through both passages. Now, one passage is a shorter than the other and is a shorter path than the other, but don't forget that the air can still be sucked in through both at the same time...
It is cool to see you all dispute Nissan's animation of VI operation but would be nice to read why you think it is not what they say it is...
Care to explain?
Cool, thanks for the educational explanation... I guess I have missed the tread on the hacking of the manifold and no open second passage...
I thought this is how VIA operated on 5th but I guess I was wrong... For me and other guys who would like to know, intake shown in the animation, what engine is it from?
http://www.sportcompactcarweb.com/te..._atunersguide/
From: a charming town in Connecticut first settled in the 1600s
What's confusing is that the URL contains "/vehicles/gallery/maxima/" and yet it doesn't pertain to the Maxima... disingenuous on Nissan's part, I'd say.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
