my right (pass. side) HID wont work
Old Apr 28, 2006 | 03:09 PM
shift_2kmaxima's Avatar
hey guys,
today when i got home, i've realized that my right hid wont work, and my high beam bulb wont work, so i took transformer, hid bulb, and the thing that holds the bulb, and hooked it up to my left (driver side) headlight, and it worked all fine....I've checked wiring on the headlight, and it seemed good.....do u guys kno what it could be? where is the fuse for the headlight? could it be blown?
thanks a lot guys
huso selimovic
Old Apr 28, 2006 | 03:47 PM
come on ppl!!!!!!!!!!!! i need help, anyone has any idea whats wrong?
i need to fix it by tonite, so i dont get a ticket...
pls help
thx
huso
Old Apr 28, 2006 | 04:15 PM
AceofSpds's Avatar
wat
Fuse should be either in the engine bay, but most likely right above your hood release latch... go through them n see if the one labled for headlights is blown.. if not check all the other ones.
Old Apr 28, 2006 | 04:38 PM
MIXXMAX's Avatar
Yeah, sounds like a blown fuse. Check in the fuse box on the right side of the battery. Should be a 15A fuse for both left and right side headlamps.
Old Apr 28, 2006 | 05:42 PM
AceofSpds's Avatar
wat
is it possible he messed up the relay?
Old Apr 28, 2006 | 05:54 PM
Zero Deuce SE's Avatar
There are 2 fuses and 1 relay for each headlight. There are two 15 amp and two 20 amp fuses. The fuses are next to the battery and the relays are next to the power steering fluid reservior.
Old Apr 28, 2006 | 07:10 PM
yeah i figured it out, and it was the 15 amp fuse.....
i have replaced it with another new 15 amp fuse, and everything works fine ....
thank you a lot guys.....
how do u deleted a thread?
this one can be deleted now....
huso
Old Apr 28, 2006 | 07:11 PM
You're welcome. Glad you got er dun.
Old Apr 28, 2006 | 08:04 PM
yeah i was happy when it came on .......
Old Apr 28, 2006 | 08:19 PM
AceofSpds's Avatar
wat
make shure you keep 1 or 2 extras in your dash or in the extra fuse slots incase it happens again to you
jerrod99_se-l
Aug 27, 2015 08:27 PM
KristyKarina
Aug 23, 2015 09:53 AM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
kenc15
Aug 5, 2015 08:29 AM
