Plenum Spacer pulled 3 times on Dyno FYI
Old May 9, 2006 | 04:39 PM
  #121
VQuick's Avatar
Chassis Freak
Barc, some comments:
1. Ever heard of air-cooled engines like the old VWs had? Of course water is much better for cooling metal parts, but air cooling worked well enough to keep those engines running, no matter what you or anyone says about the poor thermal transfer properties of air.
2. How does a hairdryer or heat gun work? The air is blown quickly at x cfm over a hot heating element, and it comes out feeling pretty toasty, even though it was at room temperature a second before.
3. If you walk fast enough on hot coals, you won't get burned but the soles of your feet WILL heat up significantly, no matter how fast you walk.
4.
Originally Posted by Barc
So, no matter how hot the intake gets, the air will never get any hotter than it normally would unless you are decreasing the rate of flow or increasing the thermal transfer rate of air, which the spacer does none of.
Think of it thus: If you had a thermometer on the intake plenum and measured the temperature at various throttle positions, it would go down as the throttle position increased due to the greater quantity of air passing through it and cooling it. As you know, when two substances come in contact with each other, the one with greater heat transfers it to the other. So the metal intake is transferring heat to the air, and where is the air going? Right into the engine. The faster the air is going, the MORE heat is going back into the engine and the less dense that air is.
5.
Yes, the specific heat is greater but air is not absorbing it any quicker at a high or low temperature.
Patently false. Any material at 150 degrees will transmit heat to anything it contacts faster, yes FASTER, than if it were at 100 degrees.
6.
If this was such an important factor, don't you think your car would permanently be pinging after it warms up due to detonation now since the intake is so hot? It doesn't, does it? Why?
Of course not. The air itself transfers little heat to the engine. You are confused. Pinging is due to early detonation, which has to due with the fuel octane rating and air-fuel ratio and other factors. The intake air temperature has an extremely minor effect on the temperature inside the cylinder. HOWEVER, (and this is the whole point) the cooler the intake air the more you can pack in due to its greater density.
7.
Given the amount of time it spends in the intake plenum, whether spaced or not, the air does not have enough time to heat beyond any point it normally would have reached so my arguement that the amount of time it spends in the chamber IS material.
Your entire argument is founded on the decidedly unscientific notion that hey, the air is going REALLY FAST so it doesn't make a difference how hot the intake is, beacuse the air is going REALLY FAST. It's in such a rush that it doesn't gain any heat from its surroundings or obey the laws of thermodynamics because it's just going REALLY FAST!
Old May 9, 2006 | 04:49 PM
  #122
Barc's Avatar
Stillen, let me ask you a question if I may. I may be way off but I've not done this in a while:
Can we use the change in heat formula (delta Q = m c delta T) to prove anything? I realize that heat is energy but hear me out and maybe I'll make a bit more sense. I have racked my brain trying to think of a short, simple way to prove that this is ineffective (in terms of temperature gradient) and this is the simplest way I could think of so anyone can understand. If it works, here is what we can easily show.
Change in heat (energy) = mass of the air X heat capacity of air X change in temperature.
Just to keep everything VERY simple, let's assume we have 1 kg of air coming into the system and staying. We already know that the change in the intake temperature is 10*F but we'll just say it is actually 10 K because this is still going to work... Therefore
Change in heat = 1kg of air X 0.963 kJ / kg X 10
Change in heat = 9.63 kJ
1 kJ = .239 kcal
So, the Change in heat = 2.3 kcal or 0.0023 Calories as measured on food...
Anyway, I may be way off but that's the simplest thing I could think of. I'm tired of trying, to be perfectly honest. I'm still in the Missouri camp!
Old May 9, 2006 | 05:01 PM
  #123
NmexMAX's Avatar
dot dot dot ...
What about at 7400' elevation... would this change anything.
Ambient air pressure is less (760 vs 590 torr)
Instead of splitting the hairs of physics, why not get a cryogenic intake from custom maxima? ...
Old May 9, 2006 | 05:08 PM
  #124
Barc's Avatar
No, you're kidding? Wow, score one for the krauts...
They blow air over a superheated coil that is red hot at a relatively low volume. If it were anything like 500 cfm, ricers would be installing transformers, ripping the coils out, and installing them in the intake piping of their cars...
I'll take your word for it and remind you that the human body is much more conductive than is air, the foot spends more time on the coals, and that the coals are about 1000* hotter than is the intake piping.
4. Think of it thus: If you had a thermometer on the intake plenum and measured the temperature at various throttle positions, it would go down as the throttle position increased due to the greater quantity of air passing through it and cooling it. As you know, when two substances come in contact with each other, the one with greater heat transfers it to the other. So the metal intake is transferring heat to the air, and where is the air going? Right into the engine. The faster the air is going, the MORE heat is going back into the engine and the less dense that air is.
Couldn't agree more about the air volume and the throttle position. However, inform me how increasing the velocity of air is increasing the temperature. Sure, some of the air is going to pick up some of the heat, however, the difference is the fact that there is more air passing over the object. The more air, the more thermal transfer, agreed, but the air is going to retain the heat at .963 kJ/kg, no matter what speed it is traveling.
5. Patently false. Any material at 150 degrees will transmit heat to anything it contacts faster, yes FASTER, than if it were at 100 degrees.
How is the thermal transfer rate of air of .963 kJ/kg affected by the temperature of the metal IM? The IM is going to give off more but the air will only "accept" the heat at that rate, no higher. This is the reason that water will only boil as fast as the thermal transfer rate will allow it to change in temperature, no matter how hot the eye on the stove is.
6. Of course not. The air itself transfers little heat to the engine. You are confused. Pinging is due to early detonation, which has to due with the fuel octane rating and air-fuel ratio and other factors. The intake air temperature has an extremely minor effect on the temperature inside the cylinder. HOWEVER, (and this is the whole point) the cooler the intake air the more you can pack in due to its greater density.
I bolded a very important portion of what you wrote. I realized when I wrote it that pinging won't occur... It was written as a jest but anyway... The density of the air is changed, how, exactly? Density of air at sea level vs. 14,000 ft (about the highest any one of us will drive) is minimal but noticable. Density of air that is 10* cooler is not...
7. Your entire argument is founded on the decidedly unscientific notion that hey, the air is going REALLY FAST so it doesn't make a difference how hot the intake is, beacuse the air is going REALLY FAST. It's in such a rush that it doesn't gain any heat from its surroundings or obey the laws of thermodynamics because it's just going REALLY FAST!
OK, you show me how it DOES work. Show me the formulas, show me the math. I can handle it, I promise. Yes, the air is not only going REALLY FAST, but CHANGING OUT every 1/8th of a second. I'm tired of trying to identify the holes in this theory and show them for what they are. Someone show me how it does, in fact, work. Don't just give me the standard line of "the air is denser" show me that 10*, hell, even 50* air will have a 9 HP effect on the VQ35DE. Were this the case, you'd have close to 300 HP in the winter when you started the car! And you'd do all your dyno testing in a meat locker.
I'm still awaiting the dyno, runfiles, and video... Remember, I've moved to Missouri.
Old May 9, 2006 | 05:29 PM
  #125
PoLo's Avatar
2-Wheelin it...
what happened to the good ol days when i could just put a Type R sticker.
Old May 9, 2006 | 05:34 PM
  #126
StillenMax80x20's Avatar
Originally Posted by BARC
OK.........
Let's use THERMODYNAMICS first law as I am now learning things
In thermodynamic terms, a system is defined as a part of the total universe that is isolated from the rest of the universe by definite boundaries
so Try plugging in this formula barc
∑(∆Q)=0
Old May 9, 2006 | 05:35 PM
  #127
NmexMAX's Avatar
dot dot dot ...
Too much energy spent.. not enough proof.
Old May 9, 2006 | 06:00 PM
  #128
BARC...
Also where is the figure of 500cfm come from? i at WOT the engine still takes less air at 3-4k than at 5-6.5k RsPM... or am i being crazy...
Old May 9, 2006 | 06:22 PM
  #129
Barc's Avatar
500 cfm is not an actual figure... its as close an approximation as I can get without doing a flow test and is entirely based on other engines flow rates that I can't quote number for number but can give a good estimate of the required volume of air required at WOT... such as the small block listed in my signature and a few others I know pretty well right off hand.
Yes, less volume is required at lower RPMs, however, WOT and high RPMs is the way dynos are done so I wanted to make sure we were on equal footing. Even at half loads, you are still swapping in new air 2 to 4 times per second.
Again, I'm tired of trying so I'm still in Missouri. Thanks for the useful input, it is appreciated!
Old May 10, 2006 | 04:21 AM
  #130
knight_yyz's Avatar
Toolie
http://wahiduddin.net/calc/calc_hp_abs.htm
-At 77F and 29.235 inches-Hg pressure and 0% humidity your engine will output 100% horsepower.
At 108F and 29.235 inches-Hg pressure at 60% humidity your engine will output 91.1% relative horsepower.
-At 98F 29.235 inches-Hg and 60% humidity your engine will output 93.5% relative horsepower.
Net Gain 2.4 % for 10 degree drop, air density increases by about .025Kg/m3
Old May 10, 2006 | 04:25 AM
  #131
bpe383's Avatar
CFM = CID x RPM x VE ÷ 3456
(source: http://www.edelbrock.com/automotive/math.html )
Given the above 214 X 6500 X .85 / 3456 = 342.1 CFM for a 3.5L
How about we spend a little more of the time researching our thoughts, and ideas before posting numbers. So, we are not wasting space and time following up with words like " not an actual figure" then going into a long drawn out post as to why it's not an actual figure.
Old May 10, 2006 | 05:10 AM
  #132
Barc's Avatar
OK. What's your point? 342 cfm / 60 seconds = 5.7 cycles per second... Air is still cycling through at over 5 times per second... So I guessed 150 cfm too high using that formula... big deal. You used the standard formula for figureing cfm used on carbed engines. Up that number by at least 25% to account for the fact that carbs aren't 100% efficient (nor is any air intake system). Want me to start a shouting match? Want me to go preach it on the mountain? Forget about it.
Spend more time researching my thoughts? That's sort of a slap in the face, don't you think, especially coming from someone who looked up cfm conversions and then misrepresented them. How about I just sit back and laugh my butt off at the fact that, even though I overestimated the cfm, the air still is swapped at a high enough rate that it still doesn't matter. And then laugh even more when every other formula quoted on here all point to the fact that this ain't gonna work as advertised.
In any event, I guessed wrong according to using a carb on the engine and I couldn't care less. Still doesn't change the outcome nor the fact that the flow is still too high.
Think I'm upset? Think you've "got me?" Think again. I told you, I've moved to Missouri. I'm having fun awaiting the dynos, video, and runfiles promised a week and a half ago now by someone who has obviously had the time to post 10+ times in various threads since then.
I'm done now fooling with this.
Old May 10, 2006 | 05:15 AM
  #133
Epacy's Avatar
Unsuccesful STL Coordinator
Smartest comment I have seen in this thread in 2 pages.
Old May 10, 2006 | 05:32 AM
  #134
Barc's Avatar
Yep, I've been almost the entire time I've started posting but people are getting too serious, myself included. I'm just gonna wait out the dynos, video, and runfiles like everyone else. I should have just listened to you several pages ago when you started asking about the validity of this guy, and not the validity of the product.
Old May 10, 2006 | 05:41 AM
  #135
PoLo's Avatar
2-Wheelin it...
can we have this thread locked until the thread-starter decides to put up runfiles, dynos, etc...
Old May 10, 2006 | 06:23 AM
  #136
UMD_MaxSE's Avatar
Got Bent?
Thread has run it's course...
If the OP has more info and supporting evidence, then start another thread...
CorollaULEV
30
Aug 9, 2021 08:11 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
incubusjohnny
Nov 3, 2015 05:18 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
