Car Stalling
Car Stalling
I've written about this along with lots of others, but here it goes again b/c it's getting worse. It used to just stall when slowing down in neutral coming to a complete stop. Then it started doing it anytime that i had to brake quickly. Then it started doing it almost anytime that I put it in neutral after reaching cruising speeds (40+). Now it will stall out just sitting at a stop light once the engine reaches normal operating temp. Any ideas? Anything is appreciated as this is not only dangerous at times, but just f-ing annoying too. Also, no codes have been thrown.
My buddies car was doing this a while back. I replaced his TPS and cleaned out the TB, it was really dirty. His car idles fine now and doesn't stall.
Id start with a TB cleaning cuz it's pretty easy and close to free. Just need some carb cleaner.
Other than that, maybe IACV or MAF.
ok, i had this as well.... i determined the IACV as the problem...IT ALSO THREW NO CODES!!!
This Started:
after: - 1 coil replacement, another corrected itself, cleaning the TB and sea foam twice in three oil changes (6k miles apart or so)
BUT
Before:
my maf went, and 02 and precat failure
this occurred DURING my trip back from Orlando on the highway at fooking 60 mph in a construction zone so i know how unsafe it was HOWEVER it stopped.... and i had forgotten about this until JUST now...
I believe it is your IACV but as far as cleaning your TB first goes (which you should do) edinanm5 on AIM for writeup.
This Started:
BUT
Before:
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
