Aftermarket bulbs
Old Jun 17, 2001 | 08:22 AM
CL2447
What are the best aftermarket bulbs that look like similar to zenons? Standard wattage for the 2000. I heard the brand new PIAA are supposed to be nice. I want the whitish purpleish look, not the cheap blue look. Thanks. Chase
Old Jun 17, 2001 | 08:49 AM
punkdork's Avatar
Try the FAQ and the Search Function. I think most go with PIAA.
Old Jun 17, 2001 | 09:02 AM
2000MaximaSE's Avatar
Piaa plasmas have the best color but suck in terms of quality and light output so i stepped up to real hid when mine burned out.. Thats wierd your name is chase. We have a guy at work named chase and we work at chase so when he calls debtors hes like, hey this is chase and they hang up on him....
Adam
Old Jun 17, 2001 | 10:06 AM
UMD_MaxSE's Avatar
Got Bent?
In terms of looks the PIAA plasmas probably look the best. I am using Raybrig White Thunder's now and they are really white with a slight hint of blue. I like those a lot. Of course, if you have the $$$ to spend the HID kit would be the way to go, no doubt
Old Jun 17, 2001 | 11:23 AM
areX's Avatar
hahah.. Raybrig!! if you can get your hands on either White Thunders or heck, even Metal Whites, you'll have nice light output.... just don't go generic... you'll lose a LOT of light.
yes, read the FAQ-U!
Old Jun 17, 2001 | 11:29 AM
yongjun's Avatar
I changed most of my friends with PIAAs over to Catz.
The catz gem bulbs have the exact same color as PIAA plasma bulbs. But when you use the high beam it gives you the same color as the low beam but only much more intense. I also recommend you try Koito white beam h4's. Very good bulbs
Old Jun 18, 2001 | 10:41 PM
Alexis's Avatar
How does the actual light output of the Catz Galaxy White bulbs compare with the Piaa Xtreme whites? This is for bulbs with the stock 60/55 wattage.
The Xtreme Whites seem to have the highest rated output of the piaa series, and the Catz give similar numbers. The stock bulbs aren't as white, but you have to admit they are pretty bright for stock.
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Noela
Sep 26, 2015 08:22 AM
