HOW-TO: Add LED visor lights!
Old May 8, 2006 | 04:51 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Alright, just as a forewarning, I rate this mod a 10/10 in LED difficulty. The actual install is very easy and straightforward, BUT, getting everything together is another story.
(1) Remove the visors. Pry off the larger clip with a flathead screwdriver. Remove the two phillips head screws. Unclip the power lead.
(2) Using your flathead, pry the bottom most section of the mirror assembly up and out.
(3) Pull the power wires out of the OEM assembly. They pull right out, albiet with some minor resistance.
(4) Tear the carboard backing OFF of the OEM visor. There is no turning back now. Cut off the clips for the OEM bulbs. Using a hot glue gun, glue the OEM leads back into place.
(5) Make your LED assemblies. Using PCB, cut a rectangle that is about 14 x 3 (holes). Wire the LEDs in series (+) to (-). Put a 33 ohm resistor on the (-) end and leave some length.
(6) If you are using 3mm LEDsm skip this step. IF NOT, you will need to chop off the tops of the LEDs using a dremel. I prefer this method as I can use bigger and brighter LEDs.
(6) Now, this is what you should have...
...you will see a pseudo circut. FOR THE DRIVER SIDE, the top leg is the positive, the bottom leg the negative. You will see a small peice of copper on the mirror cover. This peice completes positive lead when opened. You may need to bend the pins a touch in order to make this function as normal.
(7) Solder the respective ends as you see below to complete the circut.
(8) Test by opening the cover and supplying power to the OEM leads.
(9) Reinsert the OEM wires, and enjoy!
PASSENGER SIDE:
(1) The leads are reversed. Negative is top, positive is bottom. Don't ask me why.
IF YOU BREAK THE OEM COPPER CONNECTOR
Prepare for hell. You will need to glue a small peice of wire onto the end of the OEM plastic. THEN, you will need to cut is and fashion it such that when the mirror opens, it completes the circut. THIS IS NOT FUN, SO BE D'AMN CAREFUL!!!!
Old May 8, 2006 | 05:31 PM
ZIPPIN's Avatar
Mauja He Mauja
Nice. I e-mailed several companies about brighter bulbs..This is better than replacement bulbs...
Old May 8, 2006 | 05:32 PM
trigger005's Avatar
looks awesome, good job but not worth the effort IMO
Old May 8, 2006 | 07:36 PM
Yeah, this was hella insane.
Old May 8, 2006 | 08:23 PM
xTeCaOx's Avatar
damn bro ima have this done real soon
Old May 8, 2006 | 08:55 PM
danger300z's Avatar
where did u get the led's?
Old May 9, 2006 | 11:51 AM
Nomad's Avatar
LED KING
Old May 9, 2006 | 04:25 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
damnit... how much do u charge?
Old May 9, 2006 | 04:28 PM
Depends on the mod.
Old May 9, 2006 | 04:32 PM
KabirUTA13's Avatar
well ok here... the visors, the window switches, the guages, the dome, map, guage clusters, and the whole radio with the temp. thing .... but not all at once little by little...
KabirUTA13's Avatar
crap it came out twice... its a 5th gen also btw... i shoulda jumped on that led meet u set up
Old May 11, 2006 | 10:09 AM
BigL0U's Avatar
Hey what size are the stock blubs for visors ?
MaxLife17
Jun 27, 2019 01:37 PM
minsbang
Sep 11, 2015 08:48 PM
MaxLife17
Sep 8, 2015 02:36 PM
ef9
Sep 5, 2015 11:18 PM
