Headlight Aiming on the eBay Projectors
Old May 10, 2006 | 11:59 AM
xplosive9z's Avatar
My left headlight aiming is alot higher than my right one... how do I adjust the aiming on the headlight... I have the 00 Maxima eBay projectors..
Old May 10, 2006 | 12:25 PM
thrrrive's Avatar
If they are the same ones that I bought there is a grey **** looking thing at at the back of the headlilght that you can with turn with your hand or with a phillips point screw driver. There is also a phillips screw on the other side. Use these to adjust the projector. Be careful and keep track of the amount of turns. I am still trying to readjust mine after i went crazy with turning the screws. There is another thread a couple of weeks back about ebay projectors which had information about adjusting them also.
Old May 10, 2006 | 12:27 PM
xplosive9z's Avatar
thanks alot.. anybody have the thread link? i tried searching through google/yahoo... couldn't because it was blocked. ;\
Old May 10, 2006 | 12:30 PM
jdmaxima89's Avatar
On the pedobear bandwagon
Not to threadjack... but what about on a stock headlight? I put the projectors in, then went back to stock, and my left headlight is SLIGHTLY higher than the right.
Old May 10, 2006 | 12:32 PM
misiek's Avatar
stock lights have a a white **** need allen wrenches for that
Old May 10, 2006 | 12:42 PM
xplosive9z's Avatar
yea, my stock lights are in my basement in a box loll... i just wanna lower my left aiming so it doesn't look ugly bright in someones rear view.. their is a **** and a screw.. i don't know which to turn and which WAY to turn it... ideas?
Old May 10, 2006 | 12:45 PM
misiek's Avatar
park on level ground 25 feet from a wall
make a mark about 24-26 off the ground
then make the top of the beam touch that mark
turn the know to see if if goes up or down and you should be fine
Old May 10, 2006 | 12:51 PM
xplosive9z's Avatar
the screw or the ****?
Old May 10, 2006 | 12:55 PM
misiek's Avatar
try the know first... just dont go to hard and break something
Old May 18, 2006 | 06:02 AM
xplosive9z's Avatar
i tried it to turn the screw to the left & to the right and no difference..
Old May 19, 2006 | 07:32 AM
ope2k4's Avatar
Do you have HIDs in these projectors?
I do in my case. Believe me just follow instructions. to lower you have to turn screw or **** clockwise. you wont feel or see the difference unless the headlights are still attached to the car while you turn. Plus you have to do this at night or in a dark big garage that will give you at least 25 ft of space from the wall. Also make sure there are no missing tabs that holds the headlights on the bottom. If this one tab is missing? It could throw off the beam level and pattern.
litch
123
Jan 4, 2024 07:01 PM
doctorpullit
Oct 28, 2019 10:58 PM
magiconthetire
Oct 26, 2015 09:03 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Noela
Sep 26, 2015 08:22 AM
