removing rear pillar HELP
Old May 13, 2006 | 02:41 PM
1.8T's Avatar
Back of the car is torn apart....trying to fix the rattle.i cant remove the rear deck without taking off the pillars....I noticed a little blue button that popped out...However no other parts of the pillar are moving, and it feels like if i push or pull any harder its going to crack. Is there a secret to taking it off?
I searched, and found nothing. Help quick PLEASE
Old May 13, 2006 | 02:44 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Peel from the side closest to the door fist, lifting up and out. There are 3 tabs in total, IIRC.
Old May 13, 2006 | 02:47 PM
Hoooper
there are tabs that attatch it to the car across the top. grab a flashlight and look in between the plastic and the car and you should be able to see them. i would use a flathead screwdriver to get them out, just put the screwdriver onto the tab and pry against the weatherstriping. it worked for me.
Old May 13, 2006 | 02:56 PM
1.8T's Avatar
GOT IT! Thanks alot guys, you saved me some time and a headache!
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
