Wow it makes a BIG difference!
Old May 14, 2006 | 06:16 PM
maximaownsyou's Avatar
just got my Custom Maxima front strut bar installed today. wow does it make a difference... torqued all the bolts to 30lbs and used a towel wrapped crow bar to give a lil push on it before putting in the last bolt so it pushes against the strut mounts... it feels a million times stiffer on the front end and it isnt even close to the I.M... i love it
Old May 14, 2006 | 06:28 PM
DesiGLE's Avatar
The Boy Wonder
Sounds Good, which one did you get?
Btw Nice Car
Old May 14, 2006 | 06:36 PM
carsarecool's Avatar
Is it true that you should jack up the front end when putting one of those on then torque it and lower the car to get the bar seated better?
Old May 14, 2006 | 06:50 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
it is only your imagination.. the RSB is the only one tat makes a big difference
Old May 14, 2006 | 06:53 PM
doc2278's Avatar
Doctor D I presume???
I know what you mean,... got it on mine
Old May 14, 2006 | 06:58 PM
Stardust's Avatar
F---ing Kangaroos
Reading > boy wonder
Old May 14, 2006 | 07:14 PM
sciff5's Avatar
RSB does make a good difference but I have to say the FSTB did make a difference as well. And I have to say that I feel neither of them actually makes a difference in increasing the limits of the car, well maybe the RSB would make a marginal difference but very tiny. I think both of these mods really just improve handling feel.
Old May 14, 2006 | 07:52 PM
yeah.. i dont think there is a need to jack the car up.. just dont have 1 tire 6 inches above the other lol... yeah pushing against that bar and creating some push i think helped alot... with only man power we probably only moved it like a 1/16 of an inch anyways but im sure the force helps.
Old May 14, 2006 | 07:55 PM
SoonerFan's Avatar
Cletus
the FSTB makes a VERY minimal diffirence by itself.
the RSB makes a huge diffirence by itself
lowered with FSTB and RSB
Old May 14, 2006 | 07:57 PM
sciff5's Avatar
In feel yes... but in terms of actual limits... I dont think it makes that much of a difference. But surprisingly, which no one talks about, I felt the RSB made my car much more stable at high speed. I was cruising on the highway yesterday after installing the bar and looked down and I was doing 95 and didnt realize it. The car felt much more solid at those speeds that I didnt even realize I was going that fast.
Old May 15, 2006 | 01:24 PM
DesiGLE's Avatar
The Boy Wonder
I was asking assuming there is more than one brand.
Old May 18, 2006 | 01:27 PM
ThurzNite's Avatar
You'll notice the FSTB the most in transitions and initial turn-in. After that, the RSB takes over. Here in California, most drivers use high velocity and gentle steering. They won't feel very much benefit from FSTB, but they'll like RSB.
Auto-X drivers will love FSTB cuz it allows them to precisely place the wheels where they want them, sometimes at extreme turning angles and high angular velocity.
Haha, just kidding. None of what I said is true. If the FSTB doesn't make much difference, take it off... it's added weight anyways.
Jae
Old May 18, 2006 | 01:57 PM
hogey228's Avatar
i have the stillen FTSB, it made little difference. i think the car handles better on hard turns, soft turns = no difference. Check out the GD Progress RSB $119 shipped!!
Old May 18, 2006 | 02:21 PM
2001SE's Avatar
You forgeting about the LTB II?
That makes a huge difference to the front just like a sway bar but even more. On the potholes it feels much more dense, like the car wants to fall apart but its holding it tight from both sides.
Old May 25, 2006 | 12:04 AM
fhs8860's Avatar
i have no idea what u r talking about but heeeeey, good for u. see i am trying to get my 15 posts
Old May 25, 2006 | 04:12 AM
SoonerFan's Avatar
Cletus
newbies sucks...stop posting crap to get your count up.
Old May 25, 2006 | 04:37 AM
Epacy's Avatar
Unsuccesful STL Coordinator
Completely disagree.
The FSTB was the first, or one of the first suspension mods I did and it eliminated about 90% of the torque steer.
Old May 25, 2006 | 05:20 AM
upstatemax's Avatar
I also felt a difference in my front end when I installed the FSTB...
It much more planted, especially in sweeping turns and I also felt less torque steer.
No it is not a HUGE difference, but they do make a gerneral improvement on the Maxima.
Edit: I can give you guys a tip; if you find that it is not making a difference... Pour Seafoam all over the bar and your strut towers, you will make F1 cars look like pussbags in the corners.
Old May 25, 2006 | 01:31 PM
sleeperI35's Avatar
I read this thread and personally think that it all depends on the wear and tear of the struts on each vehicle. I felt a major difference with rubber to road contact after just the FTSB. I really don't think it has anything to do with the manufacturer making a "better" one then the next. I have Cattman's and Stillen's. They do the same thing. I did PERSONALLY feel the difference though.
Old May 25, 2006 | 02:12 PM
Stardust's Avatar
F---ing Kangaroos
Again, reading > you
minsbang
Sep 11, 2015 08:48 PM
Maxima30
Sep 7, 2015 06:13 PM
JoshG
Sep 5, 2015 10:10 PM
Maxboy23
Sep 4, 2015 06:04 PM
sdotcarter
Sep 2, 2015 09:53 PM
