shaking while braking/driving
Old May 17, 2006 | 04:57 PM
Y2k2maxse's Avatar
When i drive on the highway my steering wheel shakes a bit..when i use the brakes at high speed shakes more. ppl say my rotors are warped..but they are 1 month old brembo blank discs. i dont think they are warped. i have 1 month old non oem basic pads in front also. when the brakes heat up they make a grinding noise and i cannot figure out what this is its frustrating me so much. anybody help, please?!
Old May 17, 2006 | 05:02 PM
n3985's Avatar
大陆弟弟
If on the highway and you brake, if your steering wheel shakes and you can hear a "duh duh duh" sound, then your rotors are warped.
Old May 17, 2006 | 05:04 PM
MaxBoost925's Avatar
Drug Money
My guess is your bearing is shot. Lift the front of the car with the wheels on. Then try wiggling the wheels. If it moves, the bearings are shot.
If they are shot. Don't drive the car anymore until you get it fixed. I found out today that my hub is shot because of my bearing.
Old May 17, 2006 | 06:15 PM
super6's Avatar
first guess are rotors, but i know brembo blanks are great so unless u put them in ice right after hard driving, or way way overtightning lug nuts its not them. also did u change rotors and pads at same time? could be reason but also highly unlikely.
maybe try to reballance the wheels.
then id look at the bearings.
Old May 18, 2006 | 07:11 AM
boondoxmax's Avatar
First what kind of pads are you using. If you are using semi metallic then switch to ceramic and then have your rotors turned. Your rotors have metallic pieces inbedded in your rotors causing the steering wheel to shake when you brake. Turning them will get rid of the metal piece in your rotors and cermic pads will solve that problem
Old May 18, 2006 | 08:02 AM
CCS2k1Max's Avatar
Were the new pads bedded properly??? Throwing all the money in the world won't fix a thing unless you bed the pads properly.
Old May 18, 2006 | 08:44 AM
sarmstrong's Avatar
boondoxmax's Avatar
Car: 2003 Polished Titanium 03 6 Speed SE
Buyer/Seller Rating: (0)
boondoxmax is on a distinguished road
Yeah, i had semi metallic put on mine once and they made a grinding sound all the time. Realized they messed up and needed ceramic, grinding went away. Shaking could be numerous things
Old May 18, 2006 | 01:07 PM
claudiusmaximas's Avatar
ive noticed that on my maxima too...on high speeds my steering wheel shakes but i dont have new brakes or pads. ive pretty much been on the same stuff for a while now. and when i let my car sit and it rains, when i drive it again theres a loud creak from the rear wheels when i first start to reverse.
Old May 18, 2006 | 05:28 PM
Y2k2maxse's Avatar
OK...so i will switch to ceramic pads....what do you mean by have your rotors turned? like put the right on the left and vice versa? i remember hitting a HUGE POTHOLE awhile back could have knocked something off balance. ill try balancing the wheels also. and by the way thank you everyone for the input I greatlyu appreciate it.
Old May 19, 2006 | 09:07 AM
dank104's Avatar
turning your rotors means to shave your rotors so that the surface is clean and smooth.
how do you bedd new pads properly?
Old May 20, 2006 | 02:51 AM
EastSideMaxima's Avatar
A swift Bimmer driver
Guys.. Im getting my rotors and pads replaced soon... Is there anything else to be replaced while I am at it.. like bearings? please advise...
Old May 20, 2006 | 05:55 AM
super6's Avatar
you know i just took a long trip and noticed the same thing, as i go above like 75 i do hear a bit of the duh duh duh. i hope its not the bearings!!! also when braking at high speed i get that sound a bit of vibration.
Old May 22, 2006 | 06:20 AM
CCS2k1Max's Avatar
http://www.raceshopper.com/tech.shtml#bedding
http://www.zeckhausen.com/bedding_in_brakes.htm
Old May 22, 2006 | 08:39 AM
dank104's Avatar
thanks CCS2k1Max!
Old May 23, 2006 | 05:19 AM
Y2k2maxse's Avatar
new tires on soon..im doing a realignment and balancing the wheels...ill let you guys know whether this fixes my problem of shaking at high speed.
Old May 23, 2006 | 06:52 AM
MaxDom03's Avatar
I have a similar problem, that I didnt think warranted a new thread. Sometimes when I break (around 5-10mph) my car pulls hard to the left or right. Any ideas on what that could be? My steering wheel also rattles/shakes at 70mph +
Old May 23, 2006 | 11:42 AM
Blessed Hammer's Avatar
I have the same problem and I'm about to get my bearings replaced. I'll tell you how it goes.
Old May 23, 2006 | 11:59 AM
Y2k2maxse's Avatar
how much to replace the bearings?
Old May 23, 2006 | 12:04 PM
Local shop said it would be $220, but I'll let you know the real cost once I pick up the car probably later today.
Old May 23, 2006 | 12:16 PM
HitManSE's Avatar
Bearings/your alighnment/tire balance is off & your rotors are warped.
No I didnt read the other posts.
Old Jul 12, 2007 | 12:13 PM
bpowell7's Avatar
I got an 03 from a Mazda dealership about 10 days ago. It shakes a little bit when I drive on the interstate. It came with a 30 powertrain warranty and does anyone know if that should be covered in the warranty?
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
Bonka
Sep 14, 2015 11:18 PM
