Place Racing + Hybrid CAI - nice results
Old May 31, 2006 | 08:40 PM
  #41
joebangaa's Avatar
josh.. which filter are you using?
Old May 31, 2006 | 09:13 PM
  #42
kingofsorrow's Avatar
Originally Posted by irish44j
nice...I may have to think about doing that as well. Also considering relocating the battery to the trunk for better weight distro, but we'll see.
Is that an AEM water bypass valve on your intake?.
in was told that the bypass valve is AEM, i can't tell. i just like the sound this bad boi makes.
Old Dec 3, 2007 | 11:47 AM
  #43
02Maximan's Avatar
Ok I know this an OLD thread but I have a question regarding this subject so why start a new thread? I purchased the used PR CAI out the for sale section and its from a 2000. I have a 2002 so if I use the midpipe i will have to cut off the "triple head" on the breather pipe to make it work. I'm just planning on using the stock resonator instead. Those of you that have the hybrid setup, did you have fitment problems because it looks to me like the PR mid pipe is a bit longer than the stock resonator. Apparently it works but I'm wondering how exactly. Also the the template says its for a 2000 so I'm assuming its the same for the 2002 right?
Old Dec 5, 2007 | 03:34 PM
  #44
irish44j's Avatar
retired moderator
it should still fit, but the angle will be a bit off. On mine, my fuse box had to be remounted a bit crooked and I have a piece of rubber hose that I use as a "bumper" where the PR pipe curve hits the fenderwell. Other than those little things, it should work fine.
Old Dec 6, 2007 | 08:22 AM
  #45
02Maximan's Avatar
Ok sounds good. Would it help to cut the hole a hair lower than where its supposed to be? Or does it just need to be bigger?
Old Dec 6, 2007 | 07:45 PM
  #46
irish44j's Avatar
retired moderator
It will really depend on the alignment. I can't say for sure. Try the hole where it's supposed to go (using the template), and if you need to enlarge it....well, that's what a dremel is for
Old Dec 11, 2007 | 01:19 PM
  #47
02Maximan's Avatar
Another couple of questions on this setup: what are people using on the bottom of the fuse box since the white plastic piece cannot be used. Wrap the bottom with electrical tape or put a piece of insulation between it and the intake pipe or what? It doesn't seem very thorough to leave the bottom of the fuse box just open. also is the coupling between the MAF adapter and PR lower pipe connected straight? I can get the pipe to fit a lot better if connect the pipe on a bit of an angle but i think that would open to the door for a intake air leak, right?
Old Dec 11, 2007 | 09:03 PM
  #48
Torgus's Avatar
Originally Posted by GBAUER
Well, since Irish posted his modified intake, here's mine:
It's an Injen with the down-pipe removed (simple: just take off the downpipe and put the filter directly onto the MAF). I immediately noticed that I gained my torque back and lost that annoying Injen sound! It now has a deeper growl rather than a whine. Oh, and Irish, notice that the pic shows MY "camber plates".... I think I finally got the D2's dialed in right. My wife still hates the ride, but finds it somewhat tolerable now.
ya...great place to put the filter mate. behind the battery will yield MUCH cooler temps. why not stuff it next to your headers?
Old Dec 11, 2007 | 09:13 PM
  #49
SoonerFan's Avatar
Cletus
the stock injen location is so much better ...right where the fans blow heat from the radiator.
Old Dec 12, 2007 | 06:51 AM
  #50
NmexMAX's Avatar
dot dot dot ...
I see no reason to bump BAUERS pic, he doesn't even have a Maxima anymore, nor care what you or anyone ever though of it in the first place.
Old Dec 12, 2007 | 08:27 AM
  #51
SoonerFan's Avatar
Cletus
he is also no longer a member of this site.
Old Dec 12, 2007 | 09:23 AM
  #52
Torgus's Avatar
omg i'm so sorry guys!!!!!!!!!!!!!!!
Old Jan 18, 2008 | 11:33 AM
  #53
02Maximan's Avatar
Hey I was wondering what filter everyone was running with this intake? I have a AEM dryflow that I put on mine but when I took it off I could about swear there was a dust film on the inside of the filter! I have an extra KN filter that would work great with this except I'm extremely paranoid about oiled filters. I have previously screwed up 2 MAFs with the oiled foam filter on my short ram. Since the filter is quite a ways away from the MAF is it ok to use the KN?
Old Jan 19, 2008 | 04:37 PM
  #54
NmexMAX's Avatar
dot dot dot ...
I have 98k and have yet to kill a MAF, I use all K&N.
Old Jan 19, 2008 | 11:10 PM
  #55
02Maximan's Avatar
Sorry for the elementry question, but how much is the appropriate amount of oil to use? Just a light mist over the whole element or do you have to actually spray each fold per instructions?
Old Jan 19, 2008 | 11:17 PM
  #56
SoonerFan's Avatar
Cletus
follow the instruction.
people over oil the filter and then try and blame K&N for blowing their MAF
Old Jan 19, 2008 | 11:37 PM
  #57
hotstartup's Avatar
Just get do GAB....it's as good or better than any of the short-rams.
Here's my version of the GAB, which worked well. Oh, and it's a free mod that actually gives you the same gains as any short-ram....
can you explain to me the benefits of this? since the holes are right over the filter, i dont see how it will absorb more air. did you just dremel the stock panel? i love the sound of intakes but after heavily modifying my legend, not really into doing an intake.
Old Jan 20, 2008 | 12:00 AM
  #58
choiiiiiiiiiii's Avatar
seriously?
Old Jan 20, 2008 | 03:31 PM
  #59
NmexMAX's Avatar
dot dot dot ...
9whp. . . . . proven by about 3 members.
Old Jan 20, 2008 | 09:45 PM
  #60
02Maximan's Avatar
So can you assume that this intake (PR CAI hybrid) makes at least as much as the GAB/PAB?
Most people say 3-5hp with a short ram.
Old Jan 21, 2008 | 03:00 AM
  #61
hotstartup's Avatar
are you talking about the GAB or cai?
Old Jan 21, 2008 | 03:30 AM
  #62
DasYears
youre running this except when you dyno right? i moved to the intake you had when you made your PB (i think) which was just TB-coupler-maf-filter. the filter seriously sits like 6" from the TB. this seems to be the best intake IMO. the difference in sound at WOT makes me believe that something is different about it. the only bad difference was that the idle AFR was TERRIBLE. could tell the car was idling bad so i hooked up the WBO2 and it was reading like 18:1 at idle. i also saw that it allowed me to pick up 1-2 % leaner on the VAFC2. not much but every % counts IMO
Old Jan 21, 2008 | 12:41 PM
  #63
NmexMAX's Avatar
dot dot dot ...
That's correct, and IIRC in my MAF mod thread, I do mention that deleting the PCV hose from the VC to the intake tract will cause a lean reading, couple that with the larger MAF I'm using and it was off the charts. I have to add about 5-8% fuel @ idle to have it idle close to stoich.
Old Jan 21, 2008 | 01:27 PM
  #64
DasYears
yeah, thats what i did (filter on the PCV). but lukily im only at +2%.
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
TKHanson
Nov 24, 2018 01:39 AM
Maximeltman
Sep 28, 2015 07:19 PM
Sep 27, 2015 08:37 AM
