Does anyone make a stiffer FRONT sway bar?
no one makes it... but you could buy an SE sway bar and ES bushings. SE sway bar is 23mm while yours is 22.
Instread of getting LTB 2 you could get subframe bushings from larrio or BlackbirdVQ, ES control arm bushings and stage 1 LTB. Sway bar does something different though.
Originally Posted by irish44j
since you have a GXE, get an SE FSB for additional stiffness. Other than that, there are no aftermarket Front bars made.
BTW the swaybar itself is $72 from Pinnacle...
also does anyone make adjustable links or atleast something beefier than stock?
Originally Posted by n3985
Does an I35 have the thicker front sway bar as well?
Originally Posted by MaxBoost925
You know, you have to drop the subframe in order to get the sway bar replaced?
It takes a mechanic about 6 hours to do the replacement job. FYI, good luck, cuz i had to replace mine.
MaxStock
Aug 14, 2015 10:03 PM
