Anyone know how you program a Nissan remote???
Old Jun 18, 2001 | 01:09 PM
MaxtOutGXE
I have an extra remote i was just wondering if any one could just help me out on how to program it. Thanks
-Justin-
Old Jun 18, 2001 | 03:19 PM
Rookwood's Avatar
This is from a USENET post by Steve Cutchen. I'm not sure if this is on his Maxima site (it probably is), but I saved it as I was told that you need to do this when replacing batteries in the remote.
Replacing remote Controller or Multi-remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
* remote controller or multi-remote control unit LCU05 is replaced.
* an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
"Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within
10 seconds. (The hazard warning lamp will then flash twice.) At this time,
the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if
door is locked using the remote controller during this ID code entry enable
state, a new ID code can be entered). At this time, the new ID code is
entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the
driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the
driver's door is opened.
NOTE
* If you need to activate more than two additional new remote controllers,
repeat the procedure "Additional ID code entry" for each new remote
controller.
* If the same ID code that exists in the memory is input, the hazard
warning lamps will flash twice but the entry will be ignored.
* Entry of maximum four ID codes is allowed and any attempt to enter more
will be ignored.
* Any ID codes entered after termination of the "setting mode" will not be
accepted. Additionally remote control signals will be inhibited when an ID
code has not been entered during the "setting" mode.
Old Jun 18, 2001 | 03:26 PM
punkdork's Avatar
Has this been added to the faq? If not, it should.
Mar 12, 2020 12:06 AM
QueensMAX
Sep 15, 2015 04:14 AM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
