2000 Calispec question
Old May 30, 2006 | 07:02 PM
Supermax95's Avatar
Do 00 Calispec y pipes have 2 or 3 O2 sensors??
Old May 30, 2006 | 07:46 PM
Jeminunguy's Avatar
it has four o2 sensors
Old May 30, 2006 | 08:31 PM
Supermax95's Avatar
In the y pipe??
Old May 30, 2006 | 09:04 PM
oldngivout's Avatar
Willing to learn
Two are in the front pre-cat, or Bank 2.
Two more in the y-pipe which contains the rear pre-cat, or Bank 1.
Old May 30, 2006 | 09:11 PM
Supermax95's Avatar
so a calispec y pipe needs 2 or 3 plugs for an o2 sensor? Reason i am asking is becuase i went under my friends 2000 and there were 3 o2's on his y pipe.....one on each end that goes into the EM's and one more in a precat, I was trying to put in a cattman ypipe that came off of my 99 but this pipe only has a place for 2 sensors and i was under the impression that it would work...The pipe looks like it would line up....is it possible to just put in a hole/thread for another o2 sensor in the middle of the pipe, or would the car throw a code?
Old May 30, 2006 | 09:28 PM
oldngivout's Avatar
Willing to learn
If you remove a pre-cat and do not put an O2 simulator in the new pipe, you will set a code. Merely placing an O2 sensor there will not work, because it's job is to report on the function of the pre-cat, which would now be missing.
Hope that makes some sense.
Old May 30, 2006 | 09:40 PM
Supermax95's Avatar
So how would i install a y pipe on a 2000 calispec maxima without getting a code when the y-pipe itself has a cat in it.
Old May 31, 2006 | 04:14 AM
nicks79's Avatar
O2 simulator.....
Old May 31, 2006 | 10:25 AM
Supermax95's Avatar
Originally Posted by nicks79
O2 simulator.....
Do i use a resister or something?? what kind?
Old May 31, 2006 | 11:01 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
the aftermarket y pipe (cali spec) will remove one precat but will not trip a cel. i had one for 2 years and did not trip it. headers are a different story all together but you do not need an a simulator or resistor to mock the heater for an aftermarket y pipe for a cali spec 00/01.
Old May 31, 2006 | 11:49 AM
Bollwerk's Avatar
Beware that there are no exhaust modifications that are CARB certified for the Maxima (regardless of year). You may still pass smog checks though. Just FYI.
http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
Old May 31, 2006 | 08:09 PM
Supermax95's Avatar
so a 00/01 calispec y pipe should have three places for o2 sensors right? Cuz i tried putting in a ypipe from a 99 calispec on a 00 calispec but the 99 had two places for o2 sensors and there were three in the stock y pipe.
Old Jun 1, 2006 | 07:24 AM
sloppymax's Avatar
cali spec will have two primaries in the exhaust manifolds and two secondaries in the y pipe. the fed spec has two primaries in the same location but only one secondary that is mounted after the catalytic converter.
Old Jun 1, 2006 | 09:18 AM
Supermax95's Avatar
see thats what's confusing me.....i know it should have 2 in the y pipe. But my friends 2000 calispec has three in the y pipe(one extra one in a precat)....
Old Jun 1, 2006 | 10:09 AM
nicks79's Avatar
thats how it should be. in Cali spec there is 3 O2 sensors. two of them are secondary. one of them is primary for the back bank od cylinders.
So you are not confused. I suggest look it on the diagram..
Old Jun 1, 2006 | 10:51 AM
Supermax95's Avatar
So why does my "calispec" y pipe have a space for 2 o2 sensors??
Old Jun 1, 2006 | 11:02 AM
nicks79's Avatar
Is it the OEM y-pipe you talking about ? The OEM CAli spec y-pipe has 3 holes for O2 sensors.
I am thinking of getting an aftermarket one, and I only see two holes for O2 sensors as you said. Basically there is missing hole for back downstream sensor. I think you need to relocated it behind the main cat, or just don't plug it in, since you will have O2 sim anyways..
thats what I plan on doing, just coil it up somewhere by the firewall.. I think its designed based on Fed spec.
Old Jun 1, 2006 | 11:08 AM
Supermax95's Avatar
Let me try to explain my predicament a little better, there seems to be a lot of confusion. I have a calispec cattman aftermartket y pipe. It has places for two o2 sensors. The y pipe currenlty in my 2000 calispec car has spaces for 3 o2 sensors.....how would i go about putting in the cattman y pipe when i need to put in 3 sensors but only have a place made for 2....
Old Jun 1, 2006 | 11:51 AM
nicks79's Avatar
Ok, one more try.
1) I assume your Cattman y-pipe doesn't replace front precat. For that you will need headers or get OEM Fed Spec exhaust manifold. Your primary left bank O2 sensor will not move, means it will stay where it is now, which is in the front precat, visible from under the hood.
2) Your right primary O2 will be replaced by your cattman y-pipe. You need that one, can't drive without primary O2 sensors. You will screw it into the cattman y-pipe.
3) Your secondary Left O2 sensor will go in the second hole in the cattman y-pipe. However, you will need to install O2 simulator, or you will get P0430 code.
4) You do not have a hole for secondary Right O2 sensor. You have two options, either to relocate it behind main catalyst, or use O2 simmulator and leave it dangling neatly somewhere. Do not unplug it, because it will throw a code, since it is a heated O2 sensor. I think O2 simulator option here is cheaper and easier.
Thats my $0.02
Old Jun 1, 2006 | 06:19 PM
Supermax95's Avatar
Ok, one more try.
Thats my $0.02
Okay thanks nick.....I just thought that the cattman y pipe would be plugg and play, i guess i was wrong...thanks!
Old Jun 1, 2006 | 07:09 PM
Supermax95's Avatar
Thats my $0.02
Why would that trip a code, its before the precat that is being removed....
Old Jun 1, 2006 | 07:16 PM
foodmanry's Avatar
Da Roller Coaster!
If you are replacing the y-pipe only it will remove the rear (bank 1) pre-cat which will NOT AFFECT THE CEL light. However, if you install aftermarket headers (removes both front and rear pre-cats) it will THROW A CEL LIGHT.
This is irregardless cali-spec or fed-spec.
Old Jun 1, 2006 | 11:02 PM
Supermax95's Avatar
Thanks for clearing that up.....I never said one word about aftermarket headers.....But one thing is your answer was wrong. There is an O2 sensor in the rear precat, and the calispec doesnt have a place for that o2.(so i'd need a simulator). If i just replace the y pipe for the cattman without worrying about that o2 sensor i will trip a cel.
Old Jun 2, 2006 | 06:17 AM
sloppymax's Avatar
i cannot think of one single member that needed an o2 simulator for an aftermarket y pipe (3.0 cali or fed spec) unless they had a bad secondary sensor and they were installing the simulator at the same time as the y pipe.
edit-i just checked my oem y pipe (01 so obviously cali spec) and it has 2 o2 bungs in it. hence why the aftermarket y pipe has 2 bungs in it
Old Jun 2, 2006 | 11:47 AM
Supermax95's Avatar
i think my 2000 is just a freak......I'll take pics of the stock y pipe when i get it out.
Mar 12, 2020 12:06 AM
RinconI30
Jun 11, 2016 08:25 PM
QueensMAX
Sep 15, 2015 04:14 AM
Bernhard
Sep 14, 2015 12:49 PM
ballerchris510
Sep 11, 2015 05:29 PM
