wow your right, this made a bigger difference
Old May 31, 2006 | 03:11 AM
maximaownsyou's Avatar
i posted a week ago saying my FSTB made a big difference and yes i still say it did but wow i just put on my progress RSB a couple days ago and i can say my maxima actually handles like a nice car and not like a beach ball on wheels. i love it for Progress
Old May 31, 2006 | 05:54 AM
SoonerFan's Avatar
Cletus
we all told you
Old May 31, 2006 | 12:35 PM
fhs8860's Avatar
what is FSTB ?
Old May 31, 2006 | 12:41 PM
Mr. Blue Sky's Avatar
Originally Posted by fhs8860
what is FSTB ?
front strut tower bar
Old May 31, 2006 | 04:45 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
now if you don't have a drop yet go for it ... for a better reponse....get some springs and Illuminas....
Old May 31, 2006 | 07:13 PM
yeah im running on tokicos and progress drop springs
Old May 31, 2006 | 07:24 PM
maxS
i got mine installed over the weekend too, but... it's not that much of a difference...
Old Jun 1, 2006 | 11:45 AM
Nomad's Avatar
Well RSB is my second suspension upgrade on my max. It does make a difference. Yesterday I ran into the 85 degree signal @ 40mph and first time have heard how tires squeel when car oversteers Won't do it again a lil scary.
Old Jun 1, 2006 | 07:38 PM
maxS
wow, that's an overstatement... i don't think maxima can oversteer ever, unless it's done on purpose... maximas naturally understeer.
Old Jun 1, 2006 | 08:01 PM
irish44j's Avatar
retired moderator
uh..
The maxima can oversteer if you set it up to oversteer. Mine is almost perfectly balanced - no understeer or oversteer.
The maxima can be made to oversteer by:
- stiff rear sway bar
- stiff rear springs and strut settings
- poly bushings in rear
- rear sitting higher (spring height)
- high rear tire pressures
- soft front sway bar (or removed FSB)
- soft front springs/struts
- lower front end
- moderate front tire pressures.
I've set it up to oversteer on a few occasions at autocrosses. A car this heavy is tough to break the rear loose on, but trust me, it can be done
Old Jun 2, 2006 | 02:43 PM
Stereodude's Avatar
It seems like you don't understand what a RSB does. The car isn't going to handle much differently as a result of the RSB. It isn't going to cut through the slalom 5mph faster or anything like that. Basically, it just keeps the car flatter in the corners, by reducing body roll. It doesn't do much beyond that.
Old Jun 2, 2006 | 03:36 PM
Nomad's Avatar
Well I know I just was excited with this new feeling thus made car oversteer.
Old Jun 2, 2006 | 05:14 PM
Zero Deuce SE's Avatar
Isn't that considered handling?
Old Jun 2, 2006 | 05:25 PM
Stereodude's Avatar
Sorta, but not exactly. It improves the subjective feel of the car through the corners, but does not improve its ability to corner.
Old Jun 2, 2006 | 07:00 PM
maxS
Originally Posted by irish44j
uh..
- lower front end
hey thanks, i guess you've sad what i implied to say
Old Jun 2, 2006 | 07:35 PM
irish44j's Avatar
retired moderator
I completely disagree with both statements. Adjusting front and rear sway bars or changing to stiffer/less stiff bars DOES have an effect on all aspects of handling, including the car's responsiveness and grip during slalom manuevers. This holds true whether it is applied on a maxima or my 1970 Triumph (which has had both sway bars changed to different rates). Since it's late and I don't feel like explaining in my own words, I'll use someone else's words. Please especially note the parts that I have highlighted.....As I see that you are an engineer, this should make perfect sense to you.
In a turn, the sprung mass of the vehicle's body rotates around an axis known as the roll center. If the vertical distance between the roll center and the center of gravity is not zero, a torque (roll moment) equal to the centrifugal force times the distance between the center of gravity and the roll center will be exerted on the sprung mass, causing the body to lean towards the outside of the turn. This force is called roll couple. The effect of roll couple is positive camber of the wheels on the outside of the turn, which reduces their cornering grip. [my note: this applies both to the torsion-beam rear suspension on our cars and to independent suspension setups]
Roll couple is resisted by the suspension's roll stiffness, which is a function of the spring rate of the vehicle's springs and of the anti-roll bars, if any. The use of anti-roll bars allows designers to reduce roll couple without making the suspension's springs stiffer in the vertical plane, which allows improved body control without compromising ride quality, at least on smooth roads.
Increasing the roll stiffness of the suspension increases the rate of weight transfer to the wheels on the outside of the turn. As more weight is applied to the outer wheels, the adhesion of the tires is increased until their limits are reached, increasing their slip angles. If the front and rear weight transfer is unequal, the slip angles of the end with the greater weight transfer will be larger, resulting in understeer or oversteer. The use of anti-roll bars allows the weight transfer of the front and rear wheels to be adjusted separately, compensating for unequal front/rear weight balance and "tuning" the vehicle's handling characteristics.
yet another argument for the "Advanced Handling and Suspension" Forum that we've been asking for and not getting.....
Old Jun 2, 2006 | 08:33 PM
sciff5's Avatar
Hey I think the advanced suspension idea is great, but I dont think theres enough people on the board who would visit it regularly so posts wouldent get a lot of attention thus not a lot of answers thus people would be less willing to ask questions in that forum.
thats the only problem I see with it
Old Jun 2, 2006 | 08:47 PM
Stereodude's Avatar
And how much faster did your max go through the slalom after you put a RSB on it? How much did the lateral G's on the skidpad improve?
Old Jun 3, 2006 | 02:00 PM
irish44j's Avatar
retired moderator
As an engineer, I would think you would be able to figure out the rationale in the info-statement I posted above, but apparently not. Maybe you should read it again and pay attention this time...else you'll continue to make uniformed statements.
But since you asked: I actually HAVE done skidpad measurements in my Triumph GT6 with the factory front and rear sway bars vs. thicker Addco sway bars at an SCCA event in the mid-90s. I don't have the precise numbers handy down to the thousandths, but the GT6 with stock suspension pulled a .87x on the skidpad, and with 2 larger sway bars (as well as poly sway bar bushings), pulled over a .9.
As to slalom...sorry no times. I autocross enough to know the difference in my overall times though, and most autox courses have multiple slalom areas. If sway bars were no improvement, SCCA would not bump cars up-class for having them.
So, I've answered your questions.....
now....explain to me, using engineering theory, why a sway bar DOESN'T improve wheel traction and handling in your view.
Old Jun 3, 2006 | 07:00 PM
NickR's Avatar
absolutely. the rsb makes a big difference. i can't wait to get mine...
Old Jun 3, 2006 | 08:44 PM
Mr. Peabody's Avatar
Perhaps you boys should look at it from a slightly different perspective. The bar is not a sway bar as much as it is an anti sway bar. It's purpose as correctly stated above is to keep the body roll to a minimum which is what it does. It will not have the same impact to the overall handling of the car as a front shock tower bar or (down lower in the suspension) lower front anti sway bar as both of those help in determining the direction of forward motion.
That rear bar is going to help you get through that Xcross more comfortably and looking better
ahh Triumph GT6 cool car. My uncle used to sell 'em but back then I could never afford to insure one!!
Old Jun 4, 2006 | 11:00 AM
Stereodude's Avatar
Originally Posted by Mr. Peabody
Perhaps you boys should look at it from a slightly different perspective. The bar is not a sway bar as much as it is an anti sway bar. It's purpose as correctly stated above is to keep the body roll to a minimum which is what it does. It will not have the same impact to the overall handling of the car as a front shock tower bar or (down lower in the suspension) lower anti sway bar as both of those help in determining the direction of forward motion.
This exactly what I've been saying...
After I put a RSB on my car it sits a lot flatter in turns, but it doesn't have appreciably more grip in the turns.
Old Jun 4, 2006 | 11:19 AM
irish44j's Avatar
retired moderator
I really hope you're kidding....the FSTB was the first thing I put on the car, and it made almost no difference at all in the handling of the car...negligible at best.
When you say 'lower anti-sway bar' I'm not sure what distinction you're making here...We are TALKING about the rear (lower) Progress sway bar, not the upper rear strut tower bar (which, I agree, does little to nothing)...
yeah I wish one of the two that I have was actually road/track-worthy right now.....but both are in various stages of rebuilt and haven't been driven in a few years
Let's see your skidpad numbers to prove it
Old Jun 4, 2006 | 07:59 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
FSTB and RSTB do almost nothing in terms of noticable handling improvement on our Maximas.
RSB on the other hand controlls the amount of body roll and keeps the back end in check over rough pavements also. RSB makes a VERY big difference in handling compared over stock, it almost makes it feel like the car has MUCH stiffer rear suspension when used with OEM suspension. There aint a HUGE diff in handling when you are slammed on JICs for instance, but it can still be felt that the RSB does its job. I've had mine on my car for 4.5 years now, it was the 1st suspension mod I've done to the car. Its a Addco swaybar and it has approx 140K miles on it with no problems.
Old Jun 4, 2006 | 08:00 PM
BEJAY1's Avatar
Conecarver
Stiffer RSB's help reduce roll couple and increase cornering forces, thus providing better skidpad numbers (a bit). It only helps slalom by reducing the body roll (um anti-sway) and increasing the responsiveness of the vehicle. Struts, SFC's, strut braces, and lower tire profiles should improve slalom more than the anti-sway bars.
Old Jun 4, 2006 | 08:37 PM
meccanoble's Avatar
Sports Button FTW
rsb...the only serious common mod left to improve my suspension.
Old Jun 4, 2006 | 09:22 PM
Sorry for the confusion I was refering to a front ASB when I spoke of one "lower down in the suspension" lower down in the Front suspension than the shock tower.
Old Jun 30, 2006 | 05:08 PM
VaporHead
FSTB makes minor differences but Max's have horrible body roll stock anyways.
Old Jun 30, 2006 | 06:09 PM
MyBlue02's Avatar
i put my stillen on tofay...and i did notice a tighter/flatter handeling at 40+..nothing to brag about...but a noticable differance.
next, rear swaybar
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
