Piston stuck?
Old Jun 4, 2006 | 09:55 AM
1MaXXfan's Avatar
Piston stuck?
Need a little advice on this. I got the driver's side done already no problem with getting the piston back in. (Using C clamp)
Passenger side (front) is taking a herculean effort to budge and get back at all.
Any suggestions? Would bleeding that caliper now help?
Thx!
Old Jun 4, 2006 | 10:06 AM
irish44j's Avatar
retired moderator
you opened the cap of the brake reservoir, right?
Old Jun 4, 2006 | 11:17 AM
1MaXXfan's Avatar
yup
First thing I did.
Old Jun 4, 2006 | 11:21 AM
5thgenmaxima's Avatar
When you replaced the pads, where the pads worn more on the passengar side? Also are the pads on both sides of the rotor worn evenly? Is there brake fluid dripping from the seals or have you had to add any brake fluid? Is the rotor chewed up?
C-clamp should do the trick. The $5.00 piston compresser tool is worth every penny.
Old Jun 4, 2006 | 12:19 PM
1MaXXfan's Avatar
details...
hey 5th, the pads are pretty even on both the driver an passenger. no fluid leaks.
just having a heck of atime getting in the passenger side with the c-clamp.
any other thoughtS?
Old Jun 4, 2006 | 02:38 PM
All out of ideas. Unless there was a block in the fluid somehow, it would be a stuck piston. If it where me I would try my damdest to push the piston back in. (A c-clamp should provide you with more than enough torque.) If it just won't budge I'd pull it off and try again. Keep in mind if you remove the caliper you WILL have to bleed the brakes and w/o air tools to pressuirzed the system it will be a 2 person job. If you end up giving up and removing the caliper and it still won't go in then you need a new caliper.
Like I sound though, if it where me I would compress the **** out of the piston.
Then again that's probably why chit breaks on me from time to time.
Maybe someone else can chime in and have a better idea before removing the caliper though.
Old Jun 5, 2006 | 12:45 PM
1MaXXfan's Avatar
Oh man this got annoying
Tried that C-clamp, even got the "brake tool" same concept. I had to give up on that and disassemble the caliper. Hence adding bleeding to the list of chores now.
So I end up having to take it off, air compressed the piston out to see WTF was going on? Everything looked fine, O ring, dust boot cover. Greased it all up and it still wouldn't budge back into place. Had to get it snug and then used a wood block and hammer, couple of serious knocks and it slid back to place.
And bleeding isn't something I enjoy doing. I ended up getting air in the system so that became another story...
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
