2k3 calipers on 2k1 ???
Old Jun 12, 2006 | 02:09 PM
1phtmax's Avatar
ok I have 2k1 and got some used 2k3 front calipers and new pads and new rotors I have been trying to bleed the brakes and I feel like they still have air. I did not change the the rear calipers but I still was trying to bleed them what to do or what to try ?
Old Jun 12, 2006 | 04:57 PM
guimar98's Avatar
It's not possible to do it properly alone.
If you drove with air in your system, you must bleed all the calipers now.
Ask someone to help you (just to pump brake pedal)
Begin by rear passenger caliper
Don't remove your wheels (acess by inside wheel under the car)
1- Ask your helper pumps brake three time and ask him to hold the pedal after the 3rd time; then loose bleed bolt until that your helper tell you that pedal is completely touches the floor.
******Pedal must be held until the bleed bolt is retighten.******
2- Repeat that 5 times for each wheels or more if you hear air when fluid
goes out.
Wheel bleed order:
Rear passenger
Rear driver
front passenger
front driver
Old Jun 12, 2006 | 05:46 PM
1phtmax's Avatar
ill try and ill let u know
thanks
Old Jun 14, 2006 | 08:42 AM
1phtmax's Avatar
Bump
did not work i tryed Wheel bleed order and brakes are bad did each caliper about 5 or 6 times ???
Old Jun 14, 2006 | 09:29 AM
MWilds 01 20th's Avatar
Has anyone tried to put the G35 Coupe Brembo calipers on the 01 maxima?
Old Jun 14, 2006 | 06:58 PM
AllGo's Avatar
Did you get them on ebay for like $60 shipped?
Those may have been mine if so, you got a good deal, those pads alone cost me $55 and it cost me $35 to ship from Atl.
Anyhow make sure you have the correct caliper on the driver/pass side. You will know as the bleeder valve will be on the top side of the piston.
If that isn't your problem I suggest getting a set of $15 russell or similar speed bleeders.
I used them and they work great, best one man bleed around.
Old Jun 14, 2006 | 08:34 PM
1phtmax's Avatar
i got them from a org member
Old Jun 14, 2006 | 08:49 PM
1phtmax's Avatar
how can i check the callipers to see if thay r good or bad?
Old Jun 16, 2006 | 08:38 PM
1phtmax's Avatar
bump............
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
