techno ecu or AFC? 02' 6-speed
Which would be better powerwise and pricewise getting the ecu done by technosquare or getting a air fuel controller? Which has its advantages? Is the the ecu upgrade worth the 500.00? And is there a big noticeable power from the ecu with boltons versus?
As for the price it will end up being about the same because an afc is about 240ish or so plus about 150 (average) for dyno tunning.
If your going to spend $595 for the TS F-spec ecu...might as well go with the Greddy Emanage Ultimate...it's the same price but you can tune MUCH better with this one...I'm sure you can easily extract 10-15whp over the TS ECU with the greddy EMU...although you do have to pay a little extra to get it dyno tuned..
but to answer your original question, in my opinion, the AFC would be the better/cheaper route...
If you're just going the N/A bolt-on route and money is an issue, then a SAFC-II/VAFC-II will suffice. Even then, gains in power from those piggybacks depend on what the state of your AFR is with your mods.
Well as far as I know the TS changes your revlimiter and also fixes the drive by wire allowing you to still utilize WOT at the top of the rev range. To my understanding this is not something that you can adjust with the EU, the revlimiter I heard was in the beta version on their latest firmware for EU but not working correctly yet. So the best answer would be BOTH! That is a sh!tload of money but the emanage will allow you to fine tune A/F and ignition and the TS to fix the rev limiter and drive by wire (TS L-spec maybe?)
What about the issue concerning drive by wire on A33B's? Is this in the works for EU.....that would be for the win
If so that would certainly cost TS some future business from our standpoint.
Originally Posted by doublea
I believe the Emanage Ultimate can also get rid of the rev limiter, I've read that somewhere, or maybe I just need a good night of sleep.
Originally Posted by Puppetmaster
According to the EU manual, it can extend the rev limiter. Has anyone ever done it successfully on a VQ? No one that I know of. Yet.
how much oil are you burning now?
Originally Posted by NmexMAX
.F/I forums MUCH? Icey did it on a 'VQ'... Not a VQ35.. but still a VQ...
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
