ES 6 spd shifter bushing impressions
Old Jun 18, 2006 | 03:02 PM
mdloops's Avatar
1) Shift action is very stiff and accurate(In a great way)
2) Notchiness is greatly reduced
3) Shifter no longer flops around under acceleration
4) Worth every penny and minute invested
5) Directions were ok. Air box needs to be removed in order to access final bushing
6) My shifter now feels like it belongs in a performance sedan!!
Awesome improvement and mod. Everybody with a 6 speed should have these installed. There are absolutely no negative side effects and the bushings are cheap ($$$ wise) and well made
Old Jun 18, 2006 | 04:13 PM
MaximusMorpheus's Avatar
Where did you get this ES shifter bushing from?
Old Jun 18, 2006 | 06:44 PM
Deckdout2's Avatar
Play with my balls
I have to install my set soon. Mine are so worn right now. I kept missing 3rd in the 1/4 a couple of weeks ago.
Thank you for the impression, that was the motivation I needed to get off my butt and install them tomorrow.
Old Jun 18, 2006 | 06:53 PM
zero2sixtyZ's Avatar
You embarrass me.
Good site to purchase from?
Old Jun 18, 2006 | 06:55 PM
Deckdout2's Avatar
Play with my balls
I got mine from Blemhco. Fairly cheap mod for a positive difference.
Old Jun 19, 2006 | 05:11 AM
chr0nos's Avatar
brian, at cattman performace is where i got mine.
Old Jun 19, 2006 | 05:25 AM
Puppetmaster's Avatar
Damn, and you've had em for how long? It takes like 30 mins to install em, slacker.
Old Jun 19, 2006 | 05:27 AM
I got mine from Steve G at www.sportcompactonly.com.
You can also get em directly from ES at www.suspension.com.
Old Jun 19, 2006 | 05:39 AM
Deckdout2's Avatar
Play with my balls
Hey man, aside from planning the wedding and more importantly, buying more mods I just haven't found the time. Get offs the nutzack....
Old Jun 19, 2006 | 06:01 AM
LoSt180's Avatar
Those ES bushings are probably one of the easiest/cheapest bang for the buck mods. I combinded that with a B&M shifter on my G20t, night and day difference! (Max is an auto)
mdloops's Avatar
Took me longer than 1/2 hour because I was having trouble getting the new "banjo" bushing back in. Other than that the install is pretty easy and only requires strong hands.
www.suspension.com seemed to have the best prices
Old Jun 19, 2006 | 06:42 AM
Anachronism's Avatar
Is the 'shifter bushings set' part # 7-1115 what we need? ($18 at http://www.suspension.com/nissancars.htm )
Old Jun 19, 2006 | 07:17 AM
mdloops's Avatar
yes, that is the one. You have to order by phone, and they can confirm you have the correct part number.
Old Jan 26, 2009 | 07:23 PM
NYC2K2MaXx's Avatar
where does it go?
Old Jan 26, 2009 | 08:47 PM
LA02MAX's Avatar
I did notice one drawback:
In second gear, there is quite a bit of vibration in the shifter at higher RPMs...only noticable when little to no throttle is applied (ie: engine braking) but it's still annoying.
Old Jan 26, 2009 | 08:49 PM
LA02MAX's Avatar
Originally Posted by NYC2K2MaXx
where does it go?
There are several. Some go right by your shifter (underneath your shift boot) and others go under the hood at the shift linkage on the side of the transmission.
Old Jan 27, 2009 | 06:15 AM
HotshotVQ35's Avatar
damn old thread..anyway wasnt there some pdf instructions to put them on? i have had them for over 3 years, i should probably get them on..lol
Old Jan 27, 2009 | 06:59 AM
You embarrass me.
http://www.energysuspension.com/pdf_instruc/17428.PDF
Just be careful on the large bushing that goes on the interior side of the cable. Don't overtighten the nut holding it in place. I did a while back and snapped my shifter cable. Not a fun replacement. Other than that, these bushings are amazing.
Old Jan 27, 2009 | 09:51 AM
PulsarGTS's Avatar
You can also just flip that nut around so a smaller surface area touches the bushing then you can full tighten it with no binding.
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
atriuum
Sep 28, 2015 01:19 PM
