OEM Navigation Back-Up CD Swap
Old Mar 8, 2007 | 11:28 AM
  #321
i35facf's Avatar
Originally Posted by Barc
If I didn't email you, it was because I probably just plain forgot, sorry about that. Give me your email addy again and I'll send you some info.
facf@hotmail.com
thks!
Old Mar 8, 2007 | 09:30 PM
  #322
disney327's Avatar
Barc, can you send me info on the ftp?
ron4247@yahoo.com
Ron
Old Mar 9, 2007 | 05:09 AM
  #323
Barc's Avatar
facf, you have PM.
disney... What sort of car do you drive? And have you been to the Crayola factory recently?! (yep, been to Easton before)
Old Mar 9, 2007 | 05:53 AM
  #324
disney327's Avatar
facf, you have PM.
*L* Haven't been to the Crayola factory in years...
I drive an '01 Q45...It's a fine car! I just need updates for MCA8 as some things are not even on the maps.... Thanks!
Old Mar 9, 2007 | 08:12 AM
  #325
Barc's Avatar
The bad thing is the fact that even the updated discs don't have everything on the maps, and I'm talking MAJOR things. The Q may need the update disc, btw.
Old Mar 9, 2007 | 12:16 PM
  #326
i35facf's Avatar
Thanks Barc!! It seems to be working just fine.
facf
Old Mar 9, 2007 | 09:13 PM
  #327
01BlackQx4's Avatar
hey guys i have the infiniti update cd if anyone needs it to be uploaded...i am almost certain that nissan and infiniti are different when it comes to the updates, however all the maps work the same. my update cd came with precise instructions for my vehicle, i had to follow Qx4 specific instructions. listed right next it to it were i35 instructions and they were completely different. Barc, i noticed too that 5.5 is pretty bad when it comes to missing things, my moms BMW has DVD nav and has everything down to home addresses whereas our navs only give us main roads....hopefully 5.6 will be a little more in depth
Old Mar 10, 2007 | 04:52 AM
  #328
Barc's Avatar
It seems to me that its the luck of the draw. I've been in some areas where roads clearly should have been on the map and weren't but other areas where roads were on the map but I thought there would be no way they'd be on there... and I'm talking paved, 4-lane roads vs. DIRT roads (yep, my Max has been in some pretty "interesting" areas; my sig pic is at the VLA in New Mexico). I don't know why Zenrin chooses the roads it chooses but it is very inconsistent. Maybe 5.6 will be better but I doubt it will be much different.
Edit:
Very strange that the updates would be different unless they changed the OS or something from 01 to 02. It could be that it isn't that Infiniti is different but that the Q is different... It may be special!
Old Mar 11, 2007 | 10:41 AM
  #329
Shaydz's Avatar
Originally Posted by thisasian
shaydz, are you going to put the update disc on the ftp? Um... please
Update Disc???? What do you mean?
Old Mar 11, 2007 | 11:39 AM
  #330
Barc's Avatar
I think he had you confused with someone else. However, the update disc that is on the ftp DOESN'T work, for me at least.
Old Mar 12, 2007 | 10:43 PM
  #331
scapeghost's Avatar
I just stumbled upon this thread via a google search. I have a 2001.5 Pathfinder LE which came with a v5.1 MCA6 CD, but it's been having problems lately recognizing the disc. Not sure how the previous owner accomplished it, but the data surface of the CD has some hazy "stains" on it that cleaning it haven't helped. Guess they couldn't just leave the disc in the drive now, couldn't they? I tried burning a copy of it, hoping that my PC's drive would be able to read it well enough to make a good copy, but the navi doesn't recognize the burned disc at all. I may try resurfacing the CD with a "disc doctor" type thing and see if that helps.
What software are you guys using to make ISOs of your discs? Any special settings needed, e.g. read subchannel data, ignore read errors, etc.?
If I could be invited to download from the server, I would greatly appreciate it, and I could give up salvaging this old nav CD. My email address is scapeghost2004 AT h o t m a i l.com. If you could, also provide info on how I could participate in the group buy of 5.6 (whenever Zenrin gets around to putting it out there).
Old Mar 13, 2007 | 05:14 AM
  #332
Barc's Avatar
scapeghost, I use MagicISO. You can DL it for free and then "patch" it to make it work with large files. No special settings, however, make sure you aren't just doing a single file type of copy, it won't work. You have to make an exact copy of the entire disc (that includes the little boot sector on the disc), that's the key. I've attempted to use the boot sector from one disc and the data file from another and even that didn't work... and any number of other combonations of file / boot sector sort of burns. Anyway, let me know if that works out. If not, I'll see what I can do.
Old Mar 13, 2007 | 07:23 AM
  #333
scapeghost's Avatar
No dice I've tried Nero, Alcohol 120%, and now MagicISO... in each case, making an image from the disc (.nrg, .mds, .iso), then burning it at the lowest possible speed to Verbatim CD-R media. Tried a different PC/drive and media just to be sure. I'm making an "exact" disc image each time, not just copying the file structure. I'm beginning to think this disc is not recoverable. Maybe the previous owner left it in the sun on the dash or something. Still odd that the navi system recognizes it sometimes, but when it does it seems to take a long time to "boot".
Old Mar 13, 2007 | 11:28 AM
  #334
Barc's Avatar
I'll see what I can do for you, then... Not sure that 6 is up, though.
You've got email.
Old Mar 13, 2007 | 01:04 PM
  #335
240se's Avatar
Good news/Bad news
Well the bad news is that I no longer have my Maxima. I traded it in this weekend. The good news is that I have a spare factory Navigation system and Bose head unit that I bought about a year ago. They are used but in perfect working condition. If anyone needs or wants them let me know.
Old Mar 13, 2007 | 01:33 PM
  #336
scapeghost's Avatar
You've got email.
Thanks again for your help Barc. I'll do the firmware update 1st and report back how it works out.
Old Mar 19, 2007 | 07:57 AM
  #337
RockyMtnMarty's Avatar
Mca-2
Hey GMANAZ and Pack6544 I'd like to get in on this too. The price would be good if we could get one more person. How do we do this??
Marty
Old Mar 19, 2007 | 10:27 AM
  #338
steven88's Avatar
Need A Light?
anybody have MCA1 version 5.5?
Old Mar 23, 2007 | 07:05 PM
  #339
Merlot02SE's Avatar
When are gas prices going down
I just got a 02 SE with the nav. Does anyone have a 5.5 version of area 9? Please e-mail me at jeffpresley@mail2christian.com
Old Mar 23, 2007 | 07:48 PM
  #340
Barc's Avatar
Something is up with the FTP right now. I've tried to contact infinite (the guy who runs the site) but haven't had any luck. I think MCA9 5.5 is up but we just can't get to it right now.
Old Mar 25, 2007 | 07:05 AM
  #341
lancems007's Avatar
Barc, I PM'ed you.
Old Mar 26, 2007 | 04:40 AM
  #342
Barc's Avatar
Lance, you've got PM.
Old Mar 27, 2007 | 02:00 PM
  #343
Barc's Avatar
PMed the new FTP info to a few folks. PM me / email me if you need it.
Edit:
I also sent out several emails with the new info.
Old Mar 28, 2007 | 09:09 AM
  #344
BMWHIGH1's Avatar
I Know This Might Be A Stupid Question But, I Have A Pioneer Avic 3, Would That Disk Work For Your Cars And Vice Versa?
Old Mar 28, 2007 | 11:04 AM
  #345
Barc's Avatar
Probably not. Is it DVD based or CD based? The Nissan discs work for the Olds Aurora!
Old Apr 2, 2007 | 07:13 PM
  #346
Still looking for the newest backup for MCA-2. Any news on how the backups are proceeding? Also what's up with Zenrin on the next update...it's way past due isn't it????
Old Apr 3, 2007 | 05:13 AM
  #347
Barc's Avatar
Marty - Yes, way past due. I'm thinking they may have forsaken us! lol I'm thinking we don't have MCA2 5.5 up on the server. Do you have access?
Old Apr 8, 2007 | 10:42 PM
  #348
Hey Barc,
This is the response I got back from Zenrin:
Dear Customer,
CD updates are released every other year. 5.6 is due to be released this November.
Thank You,
ZENRIN USA INC
Navigation Help Desk
800-777-0325
There you have it guys. If we want the newest, we'll have to wait till November...
Old Apr 9, 2007 | 04:58 AM
  #349
Barc's Avatar
Funny... they were releasing them every year until now. 5.1 was 2001, 5.2 was 2002, etc. We'll see if in November they actually release one.
Old Apr 9, 2007 | 08:22 PM
  #350
GMANAZ's Avatar
Pack6544 and RockyMTNMarty. I tried to PM you both you but don't received PM's. Email me both at CobraFan@***.net and we'll work out the details. I believe the disc is $120 plus shipping. That should be $40ea. I'll burn the copies and pay shipping. Thanks
Old Apr 14, 2007 | 01:09 PM
  #351
rgiza1's Avatar
Navigation cd's
Hi
I'm trying to replace a complete set of navigation cd's that have been stolen from my infiniti 2002 Qx4.If anyone can help with a backup copies.I'm more than willing to pay.Thanks Bob (rjgiza@comcast.net)
Old Apr 15, 2007 | 09:10 AM
  #352
Barc's Avatar
rgiza, you've got PM.
Old Apr 20, 2007 | 11:18 AM
  #353
GMANAZ's Avatar
RockyMTNMarty, shoot me an email at Cobrafan@***.net Thanks
Old Apr 20, 2007 | 12:02 PM
  #354
brusk's Avatar
Is there any CD's still needed. I travel for a living and am bored alot I could take my laptop and hit up some local dealers on test drives to see what version they have and burn them while I test drive it. Let me know what cars and versions and regions of CDs are left I'll try to help out.
Old Apr 20, 2007 | 12:04 PM
  #355
brusk's Avatar
Just thought of another question. My 02 has the Nav unit whats the best way to replace the factory tape so I can have a real system in there, going to the trunk to swap CD's sucks and I'd much rather just hook up an Ipod or storage device that I can have all my music on. If I can't find anything I guess I'll just sell the nav unit but it's kinda nice to have sometimes.
Old Apr 20, 2007 | 01:34 PM
  #356
bobjenkins's Avatar
Please send FTP Link
Hi, All:
I am interested in MCA4 (Texas). Please send the FTP link to bob.h.jenkins DELETE THIS@gmail.com
Thanks!
Old Apr 23, 2007 | 05:18 AM
  #357
Barc's Avatar
brusk, we have most of the regions there now, just not all of the latest ones. As for replacing the head unit, I would think it should be possible so long as it had inputs from multiple sources (CD player, Nav unit, etc) but I am not sure.
Bob, 4 is up there. I'll try to shoot you something this evening.
Old Apr 23, 2007 | 05:33 AM
  #358
Merlot02SE's Avatar
If anyone lives in the Southeast, I have the latest version (5.5) of MCA9. I can send you a functional copy of firmware update and map software cheap. PM me if interested.
Old Apr 24, 2007 | 08:50 PM
  #359
psiciliano's Avatar
MCA9 Florida
HI, I would like to get a copy of the Florida MCA9 disk, Thanks lot
Old Apr 25, 2007 | 05:26 AM
  #360
Barc's Avatar
psi, need your email address. What sort of car do you drive, by the way?
