all the info. you need for the 6th gen front brake upgrade
Old May 11, 2011 | 07:31 AM
  #81
phatboislim's Avatar
Originally Posted by knight_yyz
what about 16" steelies for the winter?
i know of someone that ran Z wheels (16s) at the track..i think the 16x8.5 wheels and it rubbed...but he ran them..
Old Aug 14, 2011 | 04:03 PM
  #82
SixSpeedA33's Avatar
Gonna raise this dead horse, but after all the talk about Calipers, Caliper brackets and wheels no one mentioned brake lines. Do the 5.5 lines screw right in to 6th gen calipers and gave the needed length for full lock to lock steering and suspension travel? Thx
Old Aug 14, 2011 | 04:32 PM
  #83
HotshotVQ35's Avatar
i reused my 5.5 gen lines, no problems
Old Aug 14, 2011 | 04:44 PM
  #84
Awesome, thx for reply hot
Old Aug 15, 2011 | 05:16 AM
  #85
i reused my 5th gen brake lines no problems as well. everything is bolt on.
Old Aug 15, 2011 | 09:01 AM
  #86
Brl24's Avatar
Ok so just to clarify, the "bracket" is the piece that wraps around the outside of the caliper, and the 6th gen caliper will directly bolt up to the 5.5, correct?
Old Aug 15, 2011 | 09:11 AM
  #87
NmexMAX's Avatar
dot dot dot ...
YES
People posting in here asking questions should refrain from doing so and instead take a look at the FIRST post in this thread.
Old Aug 15, 2011 | 10:59 AM
  #88
Brl24's Avatar
Originally Posted by NmexMAX
YES
Sorry I should have clarified, when working on my brakes recently I saw the bracket as being part of the caliper, and wasn't sure if there was an adaptive bracket of some sort, that I needed to do the 6th gen upgrade. I'm fairly new to working on my car, but thanks to this site I have learned a lot. I have installed spacers, new vc gaskets, a motor mount and many other regular maintenance parts, which I never would have done without the help of the org. As far as the mounting question, I did read the thread, I just thought it wouldn't hurt to double check while I was posting.
Old Aug 15, 2011 | 11:02 AM
  #89
YES
this...thats why reading is fundamental
Old Jul 25, 2012 | 01:07 PM
  #90
Setol One's Avatar
Bump! Decided to try this out bought some 20x8.5 wheels with +45 offset wrapped in 245/35/20 for my 2000 gle/gxe just left the scrap yard got the front rotors calipers loaded with decent pads +75% life left on them for $60... now just to clarify I will need to use the 6gen torque member "bracket" because it is taller correct?
Old Jul 25, 2012 | 01:10 PM
  #91
caliper bracket, caliper, pads and rotors
Old Jul 25, 2012 | 01:23 PM
  #92
Setol One's Avatar
alright cool I got all those parts off a 2004 thanks!
Old Jul 25, 2012 | 01:34 PM
  #93
no problem, thanks for searching
Old Sep 3, 2012 | 08:18 AM
  #94
om4r's Avatar
Would anyone happen to know if 2004 g35x 17" wheels (6 spoke) clear 6th gen bbk? It has similar specs to the 5.5 bars 17x7 and 45 offset.
Old Sep 6, 2012 | 06:34 AM
  #95
NmexMAX's Avatar
dot dot dot ...
I'd loosely say it would only because the V35 has the same brakes as the A34, or at least the rotor.
Old Jul 19, 2014 | 10:08 AM
  #96
driscoll_jason@ymail.com's Avatar
6gen brake upgrade
I have a 2003 BW9 TE 6 speed. I am doing this upgrade as well. Using $80 junk yard calipers painted G2 orange, centric drilled/slotted rotors, ceramic pads, stainless lines. Will take pictures when done.
Old Jul 20, 2014 | 07:48 AM
  #97
Setol One's Avatar
Don't get the drilled/slotted rotors its a waste of money and just dont work well with this setup
Old Jul 22, 2014 | 03:18 PM
  #98
Gotthismax's Avatar
Anyone know if theres any rotors that weigh less then stock 6 gen and what pads will be the best with no noise ? Best brake fluid?
Old Jul 22, 2014 | 03:27 PM
  #99
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/advanced-su...ht-rotors.html
I like Hawk HPS pads, and Motul fluid.
Old Jul 24, 2014 | 01:58 PM
  #100
Gotthismax's Avatar
What do you guys think about the power stop kit with calipers slotted rotors and pads for less then 300 wich is about the same price of re manufactured dura last calipers , dura last rotors, and pads
Old Jul 25, 2014 | 08:22 AM
  #101
NmexMAX's Avatar
dot dot dot ...
Get what you want. I got junkyard rotors for 60$ and Dutralast pads from autozone & AutoMax's Rotors. Replaced the rotors 20k ago. Still on the pads and calipers 100k later.
Spent around 220.
Old Oct 2, 2014 | 12:38 AM
  #102
mca33's Avatar
I have a 2000 Maxima SE and just found this thread regarding the 6th gen Maxima brake upgrade for the 5th gen Maxima, I didn't see an answer in this thread to the following question.
The 6th gen Maxima years they were produced is from 2004 - 2008, does it matter which year 6th gen caliper that is purchased or trim level ie SE or SL?
I presume it doesn't matter, but I wanted to check with the experts on this forum before I purchase the 6th gen calipers.
Thanks,
Mike
Old Nov 9, 2014 | 05:16 PM
  #103
mca33's Avatar
anyone know the answer to the question below?
Thanks,
Mike
Thanks,
Mike
Old Nov 9, 2014 | 05:24 PM
  #104
george__'s Avatar
This mod works on a gen 5?
I did this on a gen 5.5 and bought a refurb gen 6 caliper without care about trim, year etc.
It's a decent upgrade, floor the brakes going about 80 km/h and your car stops dead but then skids for a couple of meters lol (due to crappy tires probably).
Consider flushing the brake fluid too.
Old Nov 9, 2014 | 07:20 PM
  #105
AznRyan's Avatar
Thanks,
Mike
I did this on my 02 I35 (same as a 5.5 gen Maxima), and used 04 Maxima SE calipers sourced from tirerack.com for the front, and 02 Max SE rear calipers from partsgeek.com
There's a group deal offer for Brembo blank rotors here on the .org
04 front rotors and 02 rear rotors.
The first post states that 5th gen SE wheels won't clear the brakes.
I'm using aftermarket wheels ('12 R Spec 19's), which cleared the brakes with room to spare
Old Nov 15, 2014 | 05:46 PM
  #106
mca33's Avatar
Quote from the OP initial post
"These are DIRECT BOLT ON for ALL 5th gens (5.0 and 5.5 alike) but you can also opt to get Matt Blehm's re-location bracket on the 5.0 gen (but not the 5.5 gen) and use your stock calipers."
Thanks for your replies, but my question is, are all the calipers the same from the 6th gen maxima regardless of the trim level ie SE or SL?
Thanks,
Mike
Lakersallday24
Nov 7, 2024 07:31 PM
vingodine
45
May 21, 2016 12:46 PM
03VQMAX
Sep 25, 2015 04:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
