HOW-TO WORKLOG: LED Loaded Instrument Cluster (+60 LEDs!) BRIGHTEST ORG CLUSTER YET
Old Jun 28, 2006 | 01:47 AM
  #41
MaxBoost925's Avatar
Drug Money
you can buy heatsinks anywhere.
1) radioshack
2) fry's electronics
3) NewEgg.com
Old Jun 28, 2006 | 01:50 AM
  #42
Drug Money
great job Metal. wouldn't it be a lot easier if they had an HID instrument cluster kit? LOL.
Old Jul 2, 2006 | 04:18 PM
  #43
Metal Maxima's Avatar
SHIFT_om nom nom nom
More pics tommorow...I am shooting to finish up the project TOMMOROW!!!
Old Jul 2, 2006 | 07:28 PM
  #44
MyownNismo's Avatar
Future Camaro SS owner
Hey metal if you want I could give you a email to this guy who makes circuit boards. You could give him the info to make them and possibly mass produce them.
Here's one of his boards.
Old Jul 2, 2006 | 07:38 PM
  #45
Arek's Avatar
^^^ It looks like Metal Maximawill start mass production and with success I hope.
Old Jul 3, 2006 | 06:17 AM
  #46
Yeah, most def. Hit me up with a PM.
Having this guys info would make mass-production of LED tails a VERY REAL possibility.
Old Jul 3, 2006 | 07:37 AM
  #47
MyownNismo's Avatar
I sent him an e-mail if he's interested I'll send you there -e-mail address to give him all the info and or pics to make them.
Old Jul 3, 2006 | 10:54 AM
  #48
Loading Update now!!!
This project will be done today!!!
Old Jul 3, 2006 | 11:02 AM
  #49
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
... ok but wats the purpose of the heat sink and regulator in this project... i got side tracked by jeepiks comment lol
Old Jul 3, 2006 | 11:03 AM
  #50
KabirUTA13's Avatar
unless ur using the voltage regulator to control the the ... the... arghh brain fart.... shyt BRIGHTNESS... THERE U GO...
Old Jul 3, 2006 | 11:07 AM
  #51
Drug Money
like ahhh. dont grounding kits make your cluster brighter?
so grounding + metal's stuff = 1337 naws?
  #52
STEP VII - TEMPLATE CUTTING
The next step will be hacking the bejeezus out of the OEM plastic template. Using a dremel cutting wheel and sanding drum, simply cut away as much material as you need to fit the boards. The problem with sanding the plastic, you will find, is that the plastic does not sand so much as the friction of the wheel casues it to melt. So don't expect it to look pretty.
Old Jul 3, 2006 | 11:10 AM
  #53
KabirUTA13's Avatar
^^ nice feet... eeeeeshh the cluster template looks like it came from a burnt maxima... i know its goign to be covered..
Old Jul 3, 2006 | 11:14 AM
  #54
STEP VIII - SIGNAL BULB CHANGEOUT
While we're at it, we might as well as swap out those boring old LEDs inside the OEM template. Some of you may have bulbs, so it'd be a bit more involved. (you'll need a resistor). For those fortunate enough to have LEDs, simply heat up the solder on the opposite end, and pull the bulb out. DON'T CUT IT. The OEM bulbs are 3mm, but we might as well as upgrade to a nice 8000MCD 5mm Blue LED. Simply push the new LED through the open holes, and resolder back in.
Now, if you make the mistake of cutting the OEM leds, you will find that you might strip the copper off of the original solder points. Don't fret. If this occurs, simply sand off the silicone cover of the leads (both sides), and solder there. It ain't pretty, but gets the job done. I made this mistake only on the first bulb, I'm trusting you not to make any.
Old Jul 3, 2006 | 11:17 AM
  #55
STEP IX - TAPE, TAPE, AND MORE TAPE
Now we're ready to start attaching out templates. You've spent all this time getting up to this point, the last thing you want to do it fry the entire circut board OR the cluster, so do yourself a favor and wrap her up in electrical tape. I figured this one out after I fired my master window switch before perfecting my alternative method to LED-ing the switch.
Old Jul 3, 2006 | 11:19 AM
  #56
KabirUTA13's Avatar
after looking at ur last few pics... wat about the speedometer... woodn't u need to have that adjusted perfectly... my friend did a guage swap on his corolla and it was bout 15 mph off
Old Jul 3, 2006 | 11:20 AM
  #57
STEP X - TEMPLATE ATTACHMENT
We're finally rounding the bases now! Ok, the next thing you are going to want to do is use some glue to attach the template to the board. Apply liberally in areas that will see no metal-to-metal contact, or specifically - nowhere that would mitigate electron transfer on the LED or OEM board. Oh, yeah...don't forget to make a (+) and (-) lead to get power to the board!s! Run those wires through the OEM lighting hole.
Old Jul 3, 2006 | 11:24 AM
  #58
Well, sort of. The circut has been regulated to run at about 23mA per LED, 12V per lead. The regulator maintains a constant 12V to the circut. I did this as a safeguard as I never want to have to take this apart again...with due reason of course! The heatsink is there to prevent thermal runaway, which is the #1 killed of LEDs worldwide. You could probably run an LED at 1 amp, but the problem is that it would get too hot for the material then fry.
Just doing my part to keep them cool.
Old Jul 3, 2006 | 11:26 AM
  #59
Ah, you'll notice one of the earlied steps involved calbrating the needles. Read, my friend. I don't type everything in detail for my own sake.
  #60
Well, that's all for now. I'm heading back to the dungeon to finish this up. See you all soon!
Old Jul 3, 2006 | 04:15 PM
  #61
BewstAdd1ct's Avatar
rather than using the regulator and heatsink, you could just use the proper series circuit involving LEDs and a resistor, set up for 20-30mA, and a circuit breaker to keep them in check.
or mount the VR externally on the backlight circuit coming from the dimmer, and if you wanna get real creative, you can probably mount the VR or its heatsink to the center vent behind the dash. i suppose this MIGHT require the fan to be running to keep it cool.
Old Jul 3, 2006 | 05:20 PM
  #62
Just a different way of doing this. Problem with your suggested circut breaker would be that when and if it does see high current I would have to reset the switch everytime it blew. Additionally, it would require that the entire circut be reworked if I did something. The VR just cuts everything off at the pass.
  #63
IT WORKS!!! Sort of. Off of the battery, lol. But all of the boards have been mounted and tested, pics up tonite!!!
Old Jul 3, 2006 | 06:14 PM
  #64
MyownNismo's Avatar
Sweet. still waiting for a reply from him.
Old Jul 3, 2006 | 08:17 PM
  #65
STEP XI - WIRING
Alright, time to wire everything up. After pulling the leads of the positive and negative ends through the OEM bulb holes, you will need to solder everything to the voltage regulators. For simplicity, I suggest tying all negative leads together. Additionally, you will want to splice all of the input power lines into a single larger wire so that when it comes time to wire everything, you will only need to deal with two wires. Now, lastly, you will want to tap a single wire off of any OEM bulb point, as we will be using this as the actuator lead for you SPDT relay.
Old Jul 3, 2006 | 08:21 PM
  #66
And, as always, time to test her out! I'll let the pictures speak for themselves. I have the option of using either the AE cluster gauge overlay, or the original black one. I am going to be using the black one as I prefer the cleaner look of the white.
Old Jul 3, 2006 | 08:31 PM
  #67
BLK2BLU's Avatar
I hope Heaven looks half as good as this
Old Jul 3, 2006 | 08:40 PM
  #68
thatcarguy350's Avatar
I see the light!
Old Jul 3, 2006 | 08:42 PM
  #69
OhOhMax's Avatar
Awesome job, I love it, I will deffinately buy one if you start mass production, or even small production, lol.
Old Jul 3, 2006 | 09:06 PM
  #70
KabirUTA13's Avatar
i 35 electroluminescent mod... out the door...
L.E.D. cluster mod..... here i come... good work there bud.... yea... with all that hard work.... i'll def be paying the price for that...
Old Jul 3, 2006 | 09:20 PM
  #71
djfrestyl's Avatar
Suspension Yoda
Looks great Dan.
Now post that finalized interior thread!
Old Jul 3, 2006 | 10:00 PM
  #72
Just some teaser pics for tommorow...the computer is BLUE. I need to work on a diffuser yet, but the results were not all too shabby...
Old Jul 4, 2006 | 06:45 AM
  #73
Kevlo911's Avatar
Kevlo for President
Teaser pics with 4th gen guages FTL!
Old Jul 4, 2006 | 07:44 AM
  #74
4th gen gauges only go to 140...
This one goes to 160...
Old Jul 4, 2006 | 09:06 AM
  #75
EdgeX's Avatar
Metal, it truly is a thing of beauty.....i wish you could have the time to give me this kind of board, but alas, i will settle for my Polarg mod...hehe....again, masterful work.
Good job bro. truly great craftsmanship. Engineers know their ****!...lol
Old Jul 4, 2006 | 09:59 AM
  #76
Thank, Greg. It would not have been possible without your cluster!
Alright, the glue is setting for the needle LEDs. It's a replicate of what Import Customz sells, only with some extra goodness.
Old Jul 4, 2006 | 10:16 AM
  #77
Kevlo911's Avatar
Kevlo for President
Maybe I should buy a 5th gen cluster and send to you. Hmmmmm
Old Jul 4, 2006 | 10:31 AM
  #78
I really don't see myself doing this project EVER again.
Old Jul 4, 2006 | 10:37 AM
  #79
Kevlo911's Avatar
Kevlo for President
Arghh, I guess I will have to make one myself...
Old Jul 4, 2006 | 09:48 PM
  #80
Yayomax's Avatar
still brewin'
Originally Posted by jeepik
no offense to the rest of you guys, they are guages, they dont need to be bright, look at the road and not at the guages ( my vision is not fantastic, but i can see my guages just fine at night)
i completely understand making these for show or for looks, but they have 0 practicality
Hey buddy, I thin Mr. Dan has an apology coming his way. I'll leave the room.
