Max died the last two days, help diagnosing problem...
Old Jun 24, 2006 | 12:20 PM
wesnine's Avatar
Makers Mark
Hey all, its been a while. My 2001 Max has 76K miles and this Thurs and Fri drivng home from work (about 10 miles, 1/2 hour in the car) my car died. All power stopped and interior dash lights came on, wheel locked up, etc. On Thursday when I was about to have it jumped an hour after it died, the Max started right up. On Friday I didn't want to mess with it so I had it jumped right away and drove it home.
I recently installed a battery so my first thought is this has to be the alternator. I took it to a mechanic this AM and said I think I need a new alternator. They called me hours later and said they hadn't forgotten about me but they could not get my car to duplicate the problem so they haven't done anything yet. What am I supposed to do here? These yahoos have put 40 miles on my car and cannot get it to die. I am picking it up now and I guess crossing my fingers.
Come Monday night driving home from work, chances are I am going to be stuck on the side of the road like last Thurs and Fri. Ugh.
Any thoughts?
Thanks.
Old Jun 24, 2006 | 12:22 PM
irish44j's Avatar
retired moderator
whoa...your steering wheel locked up?? That has nothing to do with the electrical system - the steering wheel lock is a simple mechanism controlled by the key being turned in the ignition.
Old Jun 24, 2006 | 12:25 PM
wesnine's Avatar
Makers Mark
Okay, perhaps I am embellishing a little bit, I guess the "power steering" went out. All I know is I felt lucky to get it pulled over off of the road safely. I don't know anything.
Old Jun 24, 2006 | 12:33 PM
irish44j's Avatar
retired moderator
ok, thought that's what you meant.
let me think...I know I've seen someone else with this problem before....maybe some alcohol tonight will bring it back into my memory what the problem was
Old Jun 24, 2006 | 12:42 PM
NJ Devils Fan's Avatar
That happened to me once with my old('96) max. The car died, then all the dash lights came on and the power steering was dead. Although it didnt happen to you, i opened my hood and the car was on fire by the battery...
Old Jun 24, 2006 | 12:59 PM
kcowden's Avatar
It sounds like the alternator. Had the same thing happen on RT 66 in VA during rush hour.
Old Jun 24, 2006 | 01:18 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
it could be the alternator.. take it to Autozone and they will test it for free.....
Old Jun 24, 2006 | 02:24 PM
OutMaxxed's Avatar
i had the same thing happen to me. CAr died while i was in traffic and all the dash lights came on. Steering wheel didnt"lock up" its just that the power steering went. Replaced my MAF and all was good.
Old Jun 24, 2006 | 02:27 PM
wesnine's Avatar
Makers Mark
Thanks to all. Yes Irish, that sounds like a plan.
Not sure if this would help, but when it would start to die I would turn the A/C off and then it would run fine. So Friday on the way home I didn't run any lights, radio, A/C, etc, and it still died just before I made it home. When it did die the gauges all went to zero, my clock dimmed and my other dash lights came on.
If Autozone can test a battery/alternator, etc, why can't an actual mechanic. Silly me.
Also, what type of mechanic says they can't fix this unless they actually witness it die? I explained to them the problem. Seems opposite of a normal mechanic (they take your money no matter what).
Anyway, thanks.
Old Jun 24, 2006 | 02:29 PM
wesnine's Avatar
Makers Mark
HAHAHA, also, a guy there said that it was because I am running a sub in my trunk and it was taking too much power. HAHA.
Old Jun 24, 2006 | 02:36 PM
njmaxseltd's Avatar
Make sure the battery cables/connections are clean.
Check both ends, battery and vehicle contact points.
Old Jun 24, 2006 | 03:01 PM
Lontar1's Avatar
This can be true too......
Old Jun 24, 2006 | 03:20 PM
wesnine's Avatar
Makers Mark
How, it has worked fine for months and the guy that installed it knows what he is doing....
Old Jun 24, 2006 | 03:28 PM
Redstone's Avatar
Remember not everyone that tells you they know what they are doing really do. And sometimes even when they know what they are doing, they cut corners and take shortcuts and that something they definitely won't tell you. Just something to keep in mind.
Old Jun 24, 2006 | 03:51 PM
wesnine's Avatar
Makers Mark
Yes, but this is a very good friend of mine who knows everything about cars. He assured me this was not the issue when I spoke of it.
Old Jun 24, 2006 | 03:55 PM
merovi's Avatar
go to autozone and have the your battery and alternator tested for free. If either of those are not the problem then further diagnose it. But when my car dies while its running, its usually the alternator.
Old Jun 24, 2006 | 05:01 PM
foodmanry's Avatar
Da Roller Coaster!
Jeez man..just take it to autozone already and either rule out or rule in the alternator. Then we'll go from there.
Old Jun 24, 2006 | 05:24 PM
frankd121's Avatar
Sounds like your altenator is going. The same thing happened to me, except I was able to get it to the dealer before it died.
Old Jun 27, 2006 | 02:12 PM
wesnine's Avatar
Makers Mark
Battery and Alternator tested today at Autozone just fine.
Old Jun 27, 2006 | 02:51 PM
dsparekh002's Avatar
That is just hillarious!
Old Jun 27, 2006 | 03:37 PM
Jasovanni's Avatar
The sub in the trunk itself won't kill it.
However, without a capacitor it will fry alternators every few months.
Have a capacitor?
If not, replace your alternator, then get one.
You'll be fine.
J
Old Jun 27, 2006 | 08:18 PM
djfrestyl's Avatar
Suspension Yoda
Have a capacitor?
You'll be fine.
J
Capacitors are a GIMMICK, and put more strain on your electrical system than they help.
Old Jun 27, 2006 | 08:48 PM
Jasovanni's Avatar
Not the hardcore neon light ones, just a simple one that sits near the battery terminal. Prevents overloading the alternator.
Old Jun 28, 2006 | 04:43 AM
nismos14's Avatar
§è~® f®ÈÄk
Aye..... Capacitors drain power from your alternator. Everytime your bass hits it expells the juice from the capacitor. The capacitor is NOT a battery. It does not store energy, it is used to displace quick bursts of energy at a given time. What do you think happens once the cap is emptied out? It puts a strain on the electricals especially the alternator. The alternator has to work harder to re-energize the capacitor. Once that is done the cycle repeats.
A cap near the battery? How the hell would that help his sub? This makes no sense because now the path that hte extra energy would have to travel would negate the benefits. Who the f puts a capacitor near the battery?
If you look in the audio forum there are probably about 50 - 60 guys in there NOT using caps and NOT having to replace their alternators even with 2000+ watt systems.....
Old Jun 28, 2006 | 04:28 PM
wesnine's Avatar
Makers Mark
Hasn't died on me since Friday.
The sub was installed by a friend who had run it in his car for two years with no problems....
Old Jul 5, 2006 | 01:38 PM
Andrew's Avatar
Check out the voltage before you start your car. Your car battery should be around 12 volts before starting the car. After you start the car, check the voltage. It should be up around 14.5 or so. Nothing under 14 volts. If its under 14 volts, then its your alternator. If not, change the battery.
Keep us posted.
Old Jul 5, 2006 | 03:21 PM
Y2k2maxse's Avatar
Originally Posted by mx2
My car sometimes stalls (seems to idle very low when this happens, before it cuts off) on me but cranks right back up. It doesnt happen all the time, but I cant seem to figure out why? (no codes are picked up). Had the PCV valve changed last week during regular maintenace. Any suggestions appreciated.
139,000 miles.
I had this problem. Replaced my MAF sensor and no more stalling.
sctludwig
Sep 1, 2022 01:32 PM
MaxLife17
Jun 27, 2019 01:37 PM
captchaos
Mar 15, 2016 12:18 PM
MaxLife17
Sep 8, 2015 02:36 PM
nbstriker10
Sep 4, 2015 04:26 PM
