Removing oxygen sensor w/pic
Old Jun 26, 2006 | 12:37 PM
steelymatt's Avatar
Guys,
How do I remove this o2 sensor? I've tried using an adjustable wrench but it won't budge. Are there any tricks to getting this out?
Old Jun 26, 2006 | 01:03 PM
dlee275's Avatar
Spray some penetrating oil (PB Blaster or even Seafoam) on it. Then go to the store and buy an o2 sensor socket (has a slot for the wires) and when you get back you can probably break it loose with the socket.
Old Jun 26, 2006 | 01:05 PM
Love_00_Max's Avatar
Autozone carries special tools to remove O2 sensors which can be rented. Now before trying to remove the O2 sensor, run the car for a few minutes to heat up the surfaces, spray PB Blaster and then try with this special wrench that these autostores carry!!!. Good luck!!!
Old Jun 26, 2006 | 01:10 PM
SoonerFan's Avatar
Cletus
that looks rusted as hell. use some kind of liquid wrench (PB blaster, etc)
Old Jun 26, 2006 | 01:25 PM
SEmy2K2go's Avatar
Go BUCKS!!!
to what everyone ^^^ has said. You could also warm it up with an acetylene torch after your let some penetrating spray soak in. Definately rent/buy an o2 sensor socket.
Old Jun 26, 2006 | 01:31 PM
CCS2k1Max's Avatar
I got an O2 sensor socket at Sears for less than $10. I figure with the crappy OEM sensors I'd use it regularly...
OutMaxxed's Avatar
jus curious, pb blaster can be bought at any auto parts store? up to now wd-40 was the only lubricant in my vocab...
Old Jun 26, 2006 | 01:32 PM
SEmy2K2go's Avatar
Go BUCKS!!!
You can pick it up at Lowes.
Old Jun 26, 2006 | 01:33 PM
SoonerFan's Avatar
Cletus
its not really a lubricant. it eats away the rust and frees everything up
Old Jun 26, 2006 | 01:35 PM
JiggaD369's Avatar
I work at an Autozone and other than WD-40, they have Pb Blaster which is suppose to melt a foam cup, Liquid Wrench, etc. All of them do the same thing. Just spray enough and torch the SOB off the car.
Old Jun 26, 2006 | 01:46 PM
SEmy2K2go's Avatar
Go BUCKS!!!
I wouldn't really recommend cutting the sensor "off".
bumpypickle
Sep 20, 2015 08:22 AM
ac max 92
Sep 17, 2015 07:35 AM
