00 Seat Covnersion Questions
I am planning on purchasing leather seats from a 2004 infiniti i30.
They are heated + power
I currently have non power cloth.
Which wiring adapters would I need?
Thanks for your help.
And I'll probably call up Dave B to get em.
i think it is two plugs, all cars are maximas are pre wired. i think ur problem may be that the harness plug on an 04 may be diff than the plug on ur car. first just look under ur seat to see if u got harness connectors there.
then u may need the plugs from the 04 infinity and splice em into ur wires.
I looked under my seat just now and under both the driver and passenger seats I have the wires with two plugs.
Does anyone know if the connector for an 04' i30 is the same as for 2k maxima?
Also what parts would I need to connect the heated seats part?
Edit: even if the plugs were different, you can just cut the plugs off and splice the wires together no?
thanks for your help n3985..
anyone know the part #s for the switches? and i guess I need the wires too?
switches i can easily get and mod them into my center console.. but the wires that attach to these switches... you are saying they are already inside the console?
EDIT: sorry, just realized that this was an old thread bumped by a newbie (and not bumped for a good reason)
connectors are not the same.
Originally Posted by Albi860
wiring up the passenger seat is no prob, also i know a shop in philly that can do it for you. that's where i got mines done(03 max seats in 01)
Originally Posted by soonerfan
if you are getting them from dave, just call him. he will be able to tell you everything that you need to buy (and how to hook it up)
BTW! from what i heard long ago, the 00 seats are diff. than the 01-03 seats. is that correct? or has there been a breakthru in this part of the car?!?!
Hookin up power seats have been easy until now. Need a lil help figuring out where to get power for my passenger side seat. I had manual seats then got leather/powered. The driver side had the wires no problem. There were no wires to power my passenger side, i cut the harness plug from the max i took the seats from, all i need is to get power to the cord. This is what i am working with:
That little opening you see is where the wires are suppose to some from:
here is the wiring harness:
Here is where i think some power can be obtained:
Now all i need to know is where to run the wires to get power to that seat. Thanks in advance.
carid
Sep 17, 2015 05:00 AM
